sorrentinacoffee wrote:Ray: do you really, really think this is modification is totally worth it?
On the La Pavoni that I had, yes, I think it was worth all the effort. My biggest complaint, originally, with the machine was that it was very difficult to control the temperature. As soon as I installed the PID controller, the consistency of the temperature (between shots) was drastically improved.
Originally, attempting to temperature surf the machine was maddening. I would pull 5 or 6 shots and half (or more) would be out of whack as far as the temperature.
Once I installed the PID controller, the temperature swing issue basically went away. All the shots were consistent (as far as the temperature went). I found that removing the temperature variable from the mix was very helpful as far as improving the shots. It also resulted in far fewer "sink shots" due to having the temperature drastically too high or too low.
There is still some temperature drop between the boiler and the group head, which can't really be controlled. However, having the PID controller keeping the boiler (and thus the overall machine) in line does seem to help keep there as well. I guess you could say that the biggest thing the PID controller does (in addition to regulating the boiler water temperature) is to keep the machine from over heating. For example, when I steam milk (which takes the PID controller out of contention during this time) and then flip back down to the "low" setting, where the PID controller takes over control, it takes about 5 minutes for the PID controller to bring the machine back down to the target temp. This is really helpful, because it not only regulates the boiler water temperature, but also the overall machine in effect.
I've also thought about using that smaller RTD sensor in order to monitor the temperature of the group head. I was thinking about buying an extra basket and then drilling that sensor into the bottom of the basket. This would allow me to use a 2nd PID controller (in a read-only fashion) to monitor the group head temperature during the shot.
As far as the reliability of the PID controller and the electronics: if you look back over this thread, you'll see there was a lot of talk about heat issues, etc. On my machine, I did install a heat shield (which helps a lot), but in the real world, I have had zero problems with the PID controller, or with the SSR (solid state relay). During testing the SSR on the bench, it never got above around 90 degrees. Of course, I pre-heat my machine on the "II" setting, which bypasses the SSR and the PID controller; as such, most of the heavy lifting of getting the machine up to temp doesn't involve the electronics. Once the machine is warmed up, then I turn the switch back down to "I", which hands control back over to the PID controller. From that point, the PID controller and SSR are just tasked with maintaining the temperature, which doesn't really take a lot of constant power via the SSR.
I use the La Pavoni every day to make espresso. It functions flawlessly and produces really nice shots. The milk steaming is fantastic and the PID controller keeps the machine running perfectly. I can leave the machine on for an hour or more and it keeps the boiler temperature to +/- .1 degree. With the adjustable pressure regulator (and the PID controller working together), the machine makes no noise on the counter. It just coasts along happily until you pull a shot. I do have to keep an eye on the water level, however, since I removed the over heating thing on the bottom of the boiler.
Anyway, to answer your question: yes, it's worth while. It made a big difference in my case and took the machine from being sort of a headache to use to being a joy to use. As soon as the PID controller was in the mix, I went from being able to only pull one drinkable shot in about 5 to pulling all drinkable shots one after the other. Removing the temperature swing issue made a big difference, even when you still take into account the issue of having some temperature drop between the boiler and the group head. Like I say, once the entire machine is up to temperature and the PID controller has everything stabilized, it seems that even that is not much of a factor any longer.
As far as a PID controller which will turn the machine off in the event of the temperature going too high (i.e. running out of water or something), I don't know off hand. You could probably check around though. I don't believe my PID controller has that feature, but I know that Auber makes another PID controller that is purpose built for espresso machines. I think it has a couple of extra features.
Anyway, if you have any other questions, feel free to ask or post here
Ray
