First, I'm going to install some bronze bushings in the holes for the lever. I actually found what appear to be the perfect size on Amazon.com. I'll post the exact part numbers later. I was originally going to buy them from mcmaster.com (along with the replacement circlip, etc.), but Amazon had the exact size I needed, while the mcmaster ones would have needed milling. Since the holes in the steel of the handle are a bit elongated, I think the bronze bushings will be a nice upgrade. I'm just going to drill out the existing holes (in order to enlarge them slightly) and then press the bronze bushings into place. I also found a near perfect replacement for the roller bushing that moves back and forth in the group head lever slot (photos coming soon).
As mentioned, the cross pin on the back of the lever was stuck in the larger round bushing that rides in the group head. Luckily, I was able to press it out using the chain breaker/riveter for my motorcycle (see pictures below). Specifically, it's the Motion Pro Jump chain breaker. Anyway, it did a great job pressing the pin out.
Second, in addition to installing the bronze bushings (which I will have photos of next week, once I'm all done), I decided I would see about making an adjustable pressure regulator. What I decided to do was install an adjustment screw that allows you to vary the pressure on the OEM La Pavoni pressure relief valve. As you can see from the photos below, the relief valve is just a spring that presses against a 9/32" steel ball bearing. The ball seals the steam relief hole in the boiler.
In order to install an adjustment, I drilled out the hex cap for the pressure relief valve and tapped it to M10 x 1.50mm. I have also ordered a 10mm long M10 x 1.50mm allen screw, which I will use as the adjuster. I will have to shorten the length of the spring a bit, but if all goes well, it should allow me to vary the pressure at which the relief valve kicks open.
I'm not 100% sure of the exact effect changing the pressure relief setting will have (because there are many variables), but in the most simplistic terms (and after looking over this link that outlines Gay-Lussac's law), the basic concept is that lower pressure equals lower temperature. There's a formula which states:
So just off the top of my head - using the ratio in the formula above - if T1 (temp 1) is 180 degrees when P1 is 1 bar, then if you adjust the new pressure (P2) down to something more like .95 bar, then it follows that you should end up with a temp of around 171 degrees.
That's my story and I'm sticking to it...
Either way, it will be fun to have an adjustment on the La Pavoni and see if it makes any difference in the shots and/or if it allows me to leave the machine on the "I" setting for multiple shots, without having to turn the power on/off in order to keep the temperature down a bit when pulling 5 or 10 shots.
I've also ordered a Reg Barber C-flat 49.6mm tamper (Rosewood & stainless). Hopefully this will help a bit with the very mild channeling I have been experiencing near the very outer rim of the portafilter basket.
So that's what's on the agenda as far as mods go
Here are some pictures from tonight's work. As soon as the rest of the parts start showing up, I'll post some updates and of course more photos.
Ray
Here's the chain breaker, setup on the La Pavoni so I can press out the stuck lever pin
Finally! The pin is free (you can see it poking out of the right side of the press)
Here's a shot of the pressure release cap after drilling and tapping a M10x1.50mm hole in it
Here are the guts of the pressure relief mechanism. A M10 allen screw will allow for adjustment soon.
