Hi Adam,
And thanks for contributing.
uyeasound wrote:Don't be put off buying one -anyone can make great espresso with one, as long as he has a good grinder, a well fitting tamper, access to You Tube and the forums, and time to experiment and ponder. It isn't difficult in the end. It took me a few days to get reasonable espresso, a week to get good stuff, and a month to get great shots.
+1
uyeasound wrote:When you have that, experiment for flavour by altering the tamp force and grind, but always changing them in tandem so the flow rate and lever resistance aren't thrown off.
Then use a dinner fork to evenly distribute the coffee, and fluff it evenly through.
Lots of people are trying Orphan Espresso's slapshot technique, which is to grind very fine and just tamp with almost no force but to level and distribute.
http://www.orphanespresso.com/OE-SLAP-SHOT_p_2416.html Sometimes I use their slapshot device, sometimes not. I like that it catches stray grounds in the limited desk space of my office.
You can still vary dose and grind, of course. But it works for me. I don't think there's one right way to grind and tamp except for avoiding channeling and such with the guidelines on this site. Distribution is important.
uyeasound wrote:Try different timings, and even a little wiggling of the lever.
I don't see what wiggling of the lever will do. Maybe some partial pumps if needed to help with pre-infusion.
uyeasound wrote:If you find the lever comes half way through its travel before meeting much resistance, your brew head is too cool. This means the super heated water comes in, expands and forms steam, but does not heat up and pressurise enough to make good espresso. A hot brew head will draw more water in from the boiler, and hence pressurise and fill with water, giving almost immediate lever resistance to the pull, and greater shot volume in your cup.
This doesn't make much sense to me, especially "super heated water comes in, expands and forms steam, but does not heat up and pressurise enough to make good espresso."
If water hasn't entered the group, your pressure setting may be low or the machine may be warming up so there isn't enough pressure in the boiler for water to flow into the group. If the group is cool, since it's attached to the boiler, the machine in general isn't heated. Once it is heated up, even if you insert a cool portafilter for temperature control or as some people do, cool the grouphead with a wet towel, say for a darker roast, this won't change the pre-infusion. Also sometimes you won't get good pre-infusion because you haven't vented off false pressure through the steam wand.
The nice thing about these manual levers, whether Pavoni or -- added, rebadged Pavoni (Gaggia Factory, aka Tin Man, what yakster has) -- or Olympia Express Cremina, is you can do almost infinite variation to coax the best flavors from your coffee. It's a long and fun learning curve.
