pavman wrote:the end, and start with fresh -- from the tap -- the next day.
Unnecessary?
And is this 'wet/dry cycling effect' really contributing to premature wear, or damage? I haven't noticed any, but then, maybe it wouldn't be noticeable till something happens.
I'd gladly go back to topping off if my health concerns are unwarranted, and if doing so is actually better for the machine...
Tap water? You're brave
Do you use any sort of filter?
As to the question of wet/dry cycling, it's difficult to say for sure. I have noticed that when I wash my Kyocera grinder, the tolerances change ever so slightly between wet and dry. Air tends to have an oxidizing effect in a lot of cases, also. Myself, I usually always leave a bit of water in the boiler, just so the elements are still submerged and so that the joints where the rubber O-ring is located aren't constantly going from wet to dry. It may be overkill, but that's how I do it.
On a sort of related subject (speaking of oxidation), I remember the kids next door had this heavy iron railing that wrapped along their walk way. The top rail was about 1/2 or 5/8 thick - a solid square iron bar that ran along the top of the metal posts. All the kids road motorcycles and made stuff in their garage, etc. Anyway, so one day I noticed all these odd holes through the railing. Almost like someone had drilled, but then stopped as soon as they broke through. Like if you took a center drill and drilled down into the railing, but didn't always get the middle of the rail (some holes were off center, etc, etc.)
So one day I ask my friend, Josh (youngest of the 3 kids who lived next door), what the story was. Turns out, they were sitting on the rail every single day, and watching their spit cause it to rust. Each day on the way to school, they would stop, spit in the little area where they had started some oxidation and then head to school. Every so often they would chip away the rust that had formed and continue.
Can you imagine boring through 5/8" of iron with nothing more than spit and rust? They must have been doing that for several years. If you think about say 1/2 of steel, that's .500" of an inch (500 thousands). So if you wet the surface and allow it to rust, then break away the rust, maybe you have taken away a couple of thousands. Do that 250 or so times and pretty soon you have cut all the way through the railing of your mom's fence
Anyway, I just feel better having a little water in there; as opposed to having it constantly going from wet to dry.
Ray
