by michaelbenis on Sun Aug 30, 2009 6:23 am
Well, there's a few of things to say.
Firstly, as far as I am aware there was no design change that impacted on the most desirable pressure setting and pre and post-Milleniums have been set to more or less the same values, which can easily change in transit. If anything one could argue that a higher setting is more acceptable in the new machines because of their claimed superior cooling (from design changes which quite coincidentally bring down manufacturing costs).
Then, those pressure gauges just give you an idea of how things are going from day to day; they're not in any way super-accurate. In another words adjust the gauge to get the best results for you.
The Pavs generally come with the p-stats set to around 1 bar, sometimes a little bit higher, and of course they cycle over a range of around 0.2 bar.
The lower you set the p-stat, the slower the Pav will overheat.
The lower you set the p-stat the more smooth and creamy the result, but the more "blended" in flavours. If that's your style of coffee - particularly with American beans - aim for around 0.8 as the upper limit.
If on the other hand you prefer brighter coffees, like Ethiopians, which can also have a lot of different flavours in the cup, taking the p-stat up a bit will give you a slightly less rich cup but a clearer, more delineated one. Here around 1.0 or even as high as 1.2 would be your upper limit.
If you don't want to adjust for type of beans all the time, a setting of 0.9 is a good compromise.
Lastly, the higher the pressurestat setting, the higher the pressure with which the water comes through the shower head and preinfuses the coffee. Frankly I find this is influenced much more by machine design than pressure stat setting, and in fact all of these differences are pretty subtle.
My advice would be to continue getting used to the machine until you can produce really consistent espresso the way you like it, and only then consider fine-tuning things by playing with the pressure stat. Both machines are set within an acceptable range and could in fact be closer to one another than the pressure gauge readings suggest.
Lastly, obvious as it sounds, it's worth making sure your eye is level with centred on the gauge when reading it!
Cheers
Mike
LMWDP No. 237
