I've been "practicing" on mine for 5 years, and consistent microfoam still remains elusive. But, as for the shots themselves, some taste better than others -- of course! -- but they seem to be usually in the neighborhood of proper extractions.
I agree that these examples definitely look way over extracted.
In addition to the obvious: fresh coffee, proper grind, tamp, etc, I would suggest you play around with variations of the "fellini move" -- leaving the lever in the up position for a number of seconds to start preinfusion of puck, and then, lowering and raising it a few times (try experimenting with different speeds) before finally pulling the shot.
Not only does this help with infusing the puck, but it may improve the resistance in the lever too. Not sure why! (Many have written about it). If I don't have resistance and the coffee doesn't start to come until the lever is level, when the first drips come, I raise the lever all the way up again, wait a few secs, and then pull through.
What I've just described very sloppily is a rough example of the fellini move.
Keep playing and practicing. You will have your Eureka moment! And then, the next time you pull a shot, it will completely disappear!!
Part of the fun!
