La Pavoni Europiccola instructions... for newbies
A haven dedicated to lever espresso machine aficionados.
Link to "La Pavoni Europiccola instructions... for newbies"by TUS172 on Tue Mar 18, 2008 8:21 pm
I have rebuilt a number of La Pavoni Euros over the past few years and I have sold some of them on Ebay (where I bought them as 'Charity cases'). I have always sent a letter along with them (below is one of them)to help those that are just becoming acquainted with their new friend.
Perhaps it will be of some use here also...
It is somewhat 'long winded' but for those starting out with a lever it has helped.
Hi,
These La Pavonis are a well built machine and if properly cared for will last for ever. They are designed to never overheat or build up too much pressure. A fuse wired into the boiler on the older models (later models have them as replaceable or resettable fuses) to prevent overheating and a pressure relief valve for too much pressure solves that problem. The pressure relief valve is what you will hear hissing once the machine gets up to pressure on setting I.
So anyway the pressure relief valve is the part of the unit that has the small tube that is closest to the boiler. It is a small spring with a metal ball at the end that fits into a venturi mounted on the boiler. The spring is set so that it allows pressure in the boiler to be let off once the unit is up to the appropriate temperature. Why am I explaining all of this? What the last owner did to this unit was to put a heavy spring in the pressure relief valve that must have increased the pressure and heat in the boiler until it forced leaks. The only thing I can think of is that they must have thought that these units use the pressure and steam from the boiler to make espresso. So when they heard the unit hissing they thought something needed to be fixed. WRONG!
I can tell you one thing it did... it must have made the worst tasting espresso they ever tasted. By forcing steam through the grouphead to the shower screen it not only overheated the espresso grind in the portafilter; it put undo stress and heat on the grouphead gaskets, boiler gasket, sight glass seals, and to much air from boiling the water continuously burner out the heating element itself. (The older La Pavonis did not have a reset able or replaceable fuse it was inconveniently wired up inside of the heating element body and almost impossible to replace). In other words these people really messed up. These machines rely on the lever operator (you) and the piston in the grouphead to create the pressure to force hot water (approximately 200 degrees F) through the puck in the filter basket.
So that is the history of this machine as far as I can determine. What I did; was to go through it and replace all that I have found wrong with it. It has a new stainless steel heating element and gasket, a replaceable fuse (Radio Shack) to protect it from overheating, boiler to grouphead gasket, sight glass seals, spring for the pressure relief valve, and portafilter gasket. I also descaled the boiler and put new high temp wiring under the boiler (there was that old fabric kind that was horribly discolored and frayed). I also check and lubed the piston and its gaskets.
I have used this machine for 1 ½ years and it is doing great. As I said earlier, if these units are properly cared for they last and last and...well you get the idea. The only thing you will need to replace on a regular basis is the grouphead and piston gaskets. So I will just take the opportunity to give you a few tips.
Always make sure you have at least ¾ of the sight glass boiler filled before heating. But don't go way over the sight glass level either.
You can use the setting II for initial heat up but stay close by because when it gets up toward temperature it needs to be turned down to setting I to make good espresso.
Once the machine is up to temperature it will be hissing and sputtering a bit (that is perfectly normal).
I put the portafilter in with an empty basket and lift the lever fully (Just for a second or two) to let off false pressure, steam, and any impurities that may be on the shower screen.
I then take off the portafilter dry the shower screen, and filter basket and then load a filled basket into the portafilter.
I then put the portafilter into the grouphead and turn it just enough to know that it catches, but do not tighten it down yet.
Then raise the handle about ¾ of the way towards getting hot water, and then tighten down the portafilter firmly. This procedure prevents a vacuum being created above the espresso in the filter basket which usually causes channeling during the pull.
Raise the handle to the full height and allow hot water into the grouphead for about 10 - 15 seconds before starting a firm (But not hard) down stroke.
If the stroke goes very easy and you get weak espresso with no crema. You probably have too coarse a grind, have used too little espresso in the filter basket and/or you have not tamped the espresso firmly enough.
If the stroke gets choked (the lever doesn't want to go down even with very firm pressure)... It means you have either used too fine a grind, have tamped the espresso to hard and/or used too much espresso in the filter basket.
If you choke the pull do not immediately take off the portafilter! You will get a pressure release of hot water, and wet espresso all over the place. If you have gotten the handle down far enough to be past the point where hot water is introduced to the grouphead; wait for about 30 - 45 seconds without further pressure on the lever. Try the stroke down from there again. If it goes hard, don't force it, go ahead and wait for the pressure in the grouphead to release and then slowly turn the portafilter handle to relieve the pressure still in the grouphead. When it starts to 'sneeze' stop and allow it to de-pressurize.
If you did not get the handle down past the point where hot water enters the grouphead; turn the unit off and turn on the steam wand to release pressure in the boiler. But be aware that pressure may still be in the grouphead, so be careful with the portafilter.
On successive pulls you will get two or perhaps three great shots before the grouphead begins to get too hot for good espresso. The solution is to cool off the portafilter by putting it in cold water.
La Pavoni advertises that these units can pull 8 doubles... Wrong; at best you will get 5 or perhaps 6 pulls before the water level gets dangerously low to the heating element. You never want any part of it above the water line.
Well by now you realize that these machines can be quite a challenge. But once you get to know Miss Pavoni, she will make the best espresso you've ever had in your life. The espresso itself is actually creamy and the crema ooohhh... the crema!
As I mentioned earlier a lot of making a good espresso depends on you. The machine is not the problem. You have to consider the Espresso blend, the grind, the filter basket, the tamper, the tamp itself and finally the pull. Allot of variables depend on you 'the home barista'. I suggest you visit some of the many Internet sites that fanatics like me tend to visit, there is ample great information out there to help you out of any jam you may get into.
Another issue is the tamper; I don't know why a company as prestigious as La Pavoni sends a tamper of such low quality... In layman terms, "It sucks." Reg Barber makes a top of the line tamper at a fair price they will 'turn' your tamper to the measurement of your basket to within 1/10th of a mm... for your baskets the correct size is 49.4mm. If you go on their website you will see you have many choices. Do yourself a great big favor and get one.
Lastly, the single size filter basket for the La Pavoni is worthless. In the pictures I took to sell this unit I used the double basket sold by La Pavoni and it can make great espresso with practice. But if you want another double basket (as many people do) La Pavoni baskets are about
$40.00 (Outrageous!) So do yourself another great big favor... Go online and find a Internet seller that sells the "Elektra Leva 'A' machines and replacement filter baskets. They are much deeper than the La Pavoni basket yet are the same diameter. So since you already have a bottomless portafilter you can use them. They are high quality and still much cheaper than the La Pavoni baskets. You will have much more success with them in making espresso because they hold more grind.
Well that is about it. By now you may realize that I love espresso machines and I love espresso. I have three at home, one at my office and five in my shop. I collect them, I use them and I thoroughly enjoy all different types of machines... But my wife thinks I have gone a bit overboard. So I agreed to sell a few... But that does not mean I won't be tempted on Ebay by some unique find...
Have fun with your machine. Hopefully what I have written here will help you on your way to years of great espresso... enjoy!
Bob C.
(No longer a lever purist!)
LMWDP #012
TUS172
Link to "La Pavoni Europiccola instructions... for newbies"by RapidCoffee on Tue Mar 18, 2008 9:38 pm
Thanks for sharing your instructions. For newbies, it's probably worthwhile noting that some parts of this guide apply only to older (pre-Millenium) Pavoni levers. For example, the newer models have a simple on-off switch, and take a 51mm basket (the Elektra basket will not fit). Double baskets for the Millenium models are now available for reasonable prices (e.g., $12 at partsguru.com). The 51mm single baskets are actually usable, although single shots always make me think a) "what's the point?" and b) "I want more!" :)
John
RapidCoffee
Link to "La Pavoni Europiccola instructions... for newbies"by TUS172 on Fri Mar 21, 2008 11:52 am
RapidCoffee wrote:Thanks for sharing your instructions. For newbies, it's probably worthwhile noting that some parts of this guide apply only to older (pre-Millenium) Pavoni levers. For example, the newer models have a simple on-off switch, and take a 51mm basket (the Elektra basket will not fit). Double baskets for the Millenium models are now available for reasonable prices (e.g., $12 at partsguru.com). The 51mm single baskets are actually usable, although single shots always make me think a) "what's the point?" and b) "I want more!" :)
Thanks,
I found a letter that I had written last year for a Millennium that I sold. I have posted it. It is somewhat similar to the letter in this post but does contain the differrences you pointed out.
instructions-for-la-pavoni-millennium-newbies-t6507.html
Bob C.
LMWDP #012
TUS172
Link to "La Pavoni Europiccola instructions... for newbies"by Kaffee Bitte on Sat Mar 22, 2008 8:53 pm
TUS172 wrote:Lastly, the single size filter basket for the La Pavoni is worthless.
This is the only point I felt was off on this otherwise very well written instructions. I agree the single basket doesn't behave the same way as the double, but it most certainly can produce great single shots. For one thing, you have to be very careful to use the right amount of coffee. Go much above 8 grams and the shot will most likely be way off. It also helps to grind a bit coarser, maybe a step or half step (for stepped grinder users). Using the exact same grind with the single basket can easily lead to a choke, especially if you added above 8 grams. With a little coarser grind you could probably still pull the shot and have it drinkable.
Lynn G.
LMWDP # 110
____________________
Kaffee Bitte
Link to "La Pavoni Europiccola instructions... for newbies"by TUS172 on Sat Mar 22, 2008 9:24 pm
I agree... I guess its a matter of taste. I like double-doubles or even triple-doubles... Perhaps for me it is... The more volume the better... I only tried the single basket a few times and I knew it was not for me personally but that does not mean that one can't make an espresso to his/her personal taste with one... :oops:
Bob C.
LMWDP #012
TUS172
Link to "La Pavoni Europiccola instructions... for newbies"by Kaffee Bitte on Sat Mar 22, 2008 9:31 pm
Honestly, Bob, I mostly drink doubles myself, so I understand your view point. Singles can be an amazing shot though, especially when they are pulled with a single origin. Aside from the volume issues with the single shots though, it seems that many people don't use the baskets because singles take a different skill set than a double. People invest so much time in their double baskets, and start getting good shots, then switch once and the shot just isn't as good. It is just a matter of practice really and learning the right techniques, just like so much of the espresso brewing process.
Lynn G.
LMWDP # 110
Kaffee Bitte
Link to "La Pavoni Europiccola instructions... for newbies"by calb on Sun Mar 23, 2008 6:38 am
Kaffee Bitte wrote:Honestly, Bob, I mostly drink doubles myself, so I understand your view point. Singles can be an amazing shot though, especially when they are pulled with a single origin. Aside from the volume issues with the single shots (...)
That is very interesting. In my experience with the Pavoni I get the same (very small) volume with one pull of the lever either I use the single or the double basket. When you say you mostly drink doubles I assume you make 2 pulls?
And have you tried the "double basket + 1 pull" approach with a single origin?How would you compare it to the "single basket + 1 pull" approach?
calb
Link to "La Pavoni Europiccola instructions... for newbies"by Kaffee Bitte on Sun Mar 23, 2008 1:25 pm
I usually use the felini preinfusion (one or two mini pulls) for either basket. For the double basket it varies a little. I start with the felini, and then pull the first pull. If it is going well I will continue the pull to the bottom. If the pull is difficult, I only do a half pull and then start on a second pull. More often than not though I do two felini's and two full pulls. Normal volume for the two full pulls ranges from 1.5 ounce to 1.75 ounce. The one and a half pulls usually range in the 1.25-1.5 ounce area. On the single basket I also do the felini, at least one mini pull though often two. Doing so will get you much closer to an actual full single shot, at near 1 ounce. I use both the single and the double for single-origins. Each way will produce a slightly different flavor profile from the beans. Often times my single origin espressos are used more for testing a bean to use in an espresso blend. It gives me an idea of what it can add to a blend and can lead to a nice balanced blend. There are however some coffees that I drink mainly as single origins. These include DP Ethiopians, Yemens, a few others randomly (like El Salvador San Emilio! YUM!), and last but most definitely most favored Australia Mountain Top Estate!
calb wrote:And have you tried the "double basket + 1 pull" approach with a single origin?How would you compare it to the "single basket + 1 pull" approach?
I have tried both of these, yes. I truly prefer the single basket for a single pull on any SO or blend. If I am using the double basket I tend to prefer the pull techniques stated above. To me the double basket single pull leads a shot that is too intense and misses the subtle flavors. Best thing you can do is just try it out as many different ways as you can think of. You have to learn your own tastes, and find the methods that work for you.
For more reading on Multiple pulls on levers here is a good thread. There are many more out there if you dig a bit too.
http://www.home-barista.com/lever...hniques-t5471.html
Lynn G.
LMWDP # 110
Kaffee Bitte
Link to "La Pavoni Europiccola instructions... for newbies"by calb on Sun Mar 23, 2008 2:00 pm
Kaffee Bitte wrote:Best thing you can do is just try it out as many different ways as you can think of. You have to learn your own tastes, and find the methods that work for you.
Yeah I think you're right. I have been using more the double basket. Now I'll start to explore the single basket with 1 or 2 felinis.
I drink mainly single origins and I have had very good results with some Guatemalas too...
calb
Link to "La Pavoni Europiccola instructions... for newbies"by calb on Sun Mar 23, 2008 7:02 pm
First efforts with the single basket loaded with 8 to 9 gr are giving a bit thinner crema than the double basket. Is this expectable or am I doing something wrong?
calb
Link to "La Pavoni Europiccola instructions... for newbies"by Kaffee Bitte on Sun Mar 23, 2008 7:20 pm
calb wrote:First efforts with the single basket loaded with 8 to 9 gr are giving a bit thinner crema than the double basket. Is this expectable or am I doing something wrong?
Sounds like you may have coarsened the grind a bit too much. Try a shot or two near your normal double range, then move back just a hair. I tend to make the grind more coarse, because it often leads to more clarity in SO shots. You may like it better at your typical grind setting. Also back down from the 9 grams, aim for 7-8. Especially if you try it with a finer grind. 9 grams in the single will often lead to a choke, and if it doesn't it is usually hitting the shower screen, which can lead to some serious channeling.
Lynn G.
LMWDP # 110
Kaffee Bitte
Link to "La Pavoni Europiccola instructions... for newbies"by brischdc on Thu Mar 27, 2008 10:00 am
I am new to the home-barista world, and also new to making espresso with a real machine. I've had some of the cheaper home models in the past, but just upgraded to a La Pavoni Millenium (51mm group) machine and a Rancilio Rocky grinder. I have been pulling some decent shots lately, inconsistent of course, but drinkable. I am wondering if anyone else, with a La Pavoni, has had a similar experience with tamper size. I have a stainless 51mm tamper from espressoparts.com, but it seems to be too small for the La Pavoni baskets. If I put the tamper all the way to one side of the basket (double is the only one I have been using), I still have at least 1-2mm of space on the other side. When I tamp, I put the tamper directly into the middle of the basket and tamp, and then have to clear "untamped" coffee off the sides of the basket. It seems like a 52mm would do a more complete job, unless my results are what I am supposed to be getting. Any thoughts out there?
brischdc
Link to "La Pavoni Europiccola instructions... for newbies"by ntwkgestapo on Thu Mar 27, 2008 10:28 am
brischdc wrote:...I have a stainless 51mm tamper from espressoparts.com, but it seems to be too small for the La Pavoni baskets. If I put the tamper all the way to one side of the basket (double is the only one I have been using), I still have at least 1-2mm of space on the other side. When I tamp, I put the tamper directly into the middle of the basket and tamp, and then have to clear "untamped" coffee off the sides of the basket. It seems like a 52mm would do a more complete job, unless my results are what I am supposed to be getting. Any thoughts out there?
Brian, I've got a Gaggia Factory 16 (basically a clone of the La Pav Pro) with the 51mm group. I've also got an EP-5 tamper, 51mm from EPNW. The tamper is exactly 51mm and it goes about 70% of the way down into my double basket before stopping. I get some of the grinds to the sides of the basket that you're talking about but haven't been worrying about it. Before my EP-5 arrived I was using a 49mm curved tamper I'd gotten years ago from $Bux. The big thing I saw with the EP-5 was an improvement in consistency from the $B tamper.
On the single basket bit, I've begun doing some experimenting with it (right now using a CCC El Salvidor SO) and seen some fairly good results... Not as good as I'd like, but then I'm not down to the 7-8 grams yet (I'll have to try that tonight). Full basket, stockfleth'd, gives me about 10.4 grams. Nice but not exactly what I was looking for, but the journey continues.
EDIT: I should have mentioned the internal diameter of the double basket I'm using (the stock double that came with the machine). 51.65mm at the top edge (actually about 5mm down from the very top. that's where my calipers want to sit! :D).
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
ntwkgestapo
Link to "La Pavoni Europiccola instructions... for newbies"by samgiles on Thu Mar 27, 2008 1:21 pm
I feel your pain. I have a pre-millenium Pavoni but for a long time struggled with a stock 49mm tamper. It's a pain getting those excess grinds out from the basket sides. Eventually I sent a basket off and had a tamper made to fit. It's made quite a difference. I think 52mm might be too big for your millenium and would suggest getting a tamper made to fit. For me it was worth the expense.
LMWDP #169
samgiles
Link to "La Pavoni Europiccola instructions... for newbies"by RapidCoffee on Thu Mar 27, 2008 5:05 pm
brischdc wrote:I have a stainless 51mm tamper from espressoparts.com, but it seems to be too small for the La Pavoni baskets. If I put the tamper all the way to one side of the basket (double is the only one I have been using), I still have at least 1-2mm of space on the other side. When I tamp, I put the tamper directly into the middle of the basket and tamp, and then have to clear "untamped" coffee off the sides of the basket. It seems like a 52mm would do a more complete job, unless my results are what I am supposed to be getting. Any thoughts out there?
Hi Brian, and welcome to H-B. I've been using a 51mm EPNW tamper with a Pavoni Millenium, similar 1-2mm gap at the top of the basket, and the fit seems OK to me. You have to expect some clearance, or the piston might bind partway down the basket. A 1mm gap is roughly the thickness of a dime, and IMHO nothing to be concerned about. That's barely 0.5mm clearance between the piston and the basket walls, less than 1% of the basket diameter. If the gap is more than 2mm I'd suggest using the Staub (NSEW) tamping style, and looking into a custom tamper.
John
RapidCoffee
www.artazza.com: exquisite demitasses and handcrafted TORR tampers
Link to "La Pavoni Europiccola instructions... for newbies"by TUS172 on Thu Jan 22, 2009 8:48 pm
I figured I would bring this thread back up since we do have some new users. :)
Bob C.
LMWDP #012
TUS172
Link to "La Pavoni Europiccola instructions... for newbies"by Chert on Mon Nov 30, 2009 1:25 am
TUS172, I agree it is a useful thread, especially for someone who plans to rehab a burned out pre-2000 Europiccola. (me) :)
Flint
LMDWP #198
Chert
Link to "La Pavoni Europiccola instructions... for newbies"by Stuggi on Mon Nov 30, 2009 5:56 am
What I would like to know is how some guys seem to get 30ml from one pull using the double basket? I don't think I can do even half that with my machine, maybe I'm grinding too fine.
Sebastian "Stuggi" Storholm
LMWDP #136
Stuggi
Link to "La Pavoni Europiccola instructions... for newbies"by calb on Mon Nov 30, 2009 6:41 am
Stuggi wrote:What I would like to know is how some guys seem to get 30ml from one pull using the double basket? I don't think I can do even half that with my machine, maybe I'm grinding too fine.
Are you actually measuring your espressos? Because 30 ml is a very small quantity, less than half a cup for most cup models...
Anyway it's a fact that grinding coarser will give you a slightly larger volume.
calb
Link to "La Pavoni Europiccola instructions... for newbies"by 180degrees on Mon Nov 30, 2009 6:48 am
There are two points to watch for when trying to get a long 30ml extraction.
1. Don't be tempted to over full the basket. For me it always needs to be at least 5-6mm down from the lip. If the basket is over fulled then you run the risk of disturbing the puck face when loading engaging the PF and, depending on your tamp weight, not getting good thorough preinfusion of the puck ie less water in the chamber.
2. The best draws are when there is good pressure right from the top of the stroke. ie no air or springyness in the initial stroke. This is a bit of a struggle. I have achieved the best results with a long preinfusion 30sec after the fellini stroke or a larger number, 4-5, of fellini strokes. There doesn't have to be a rush to start the draw, though once started it seems to pay to keep a flow going keeping an eye on the colour to determine whether to increase or decrease the stroke rate.
at the end of the stroke there should be a mixture of very dark oils from the initial pour through to the lighter crema of the end stroke giving that lovely tiger stipple.
The other technique that I have observed is that the machine needs to be on for at least 30min (this is a millenium with better heat capabilities than the pre-) to improve the air removal.
Cheers
180degrees
Next
