cannonfodder wrote:If the little red button does not push in I can almost assure you that your heating element is cooked. To check it you will need a multi meter/ohm meter. Unplug the power wires off the spades on the heating element, then put the meter test probes on it. If you get infinite ohm's you have an open circuit (blown heater) if you get resistance then the element is most likely good but given what happened I would just jump right to purchasing a new heater element.
