The good news is she fired right up and cycled nicely around 1.1 bar according to the gauge. No obvious leaks to be found although everything clearly needs rebuild.
There is some evidence of un-qualified repair work, some bad soldering and a boiler that looks to be sealed on with kitchen caulking. The boiler base is 1 turn off from where it should be so all the pipes have been bent to accomodate the new orientation of the base. (You would think that just remounting the base would be easier, but maybe not if you have already caulked it in place).
All things aside this seems to be a good candidate for restoration and i'm eager to get started.
First things first; sourcing a boiler gasket. Doug, if you are out there I know you have done a Eurobar before and i'm wondering if you cut your own boiler gaskets (one above and below the frame base) or if I can use the same gaskets as the EP Professional?
I'm also missing the original drip tray. I'm not sure where all the drip trays go but they always seem to be missing for some reason. If anyone has a lead on a replacement I'd love to hear about it, otherwise i'll have to fabricate something.
A couple of pics as she is today. The colour is actually Italian red, it looks more orange in these photos.
