La Pavoni DIY Naked Portafilter
Postby RayJohns on Mon Sep 27, 2010 6:46 am
Well, I was going to order a 49mm naked portafilter for use on my little used La Pavoni (which I recently bought off Craigslist), but instead I decided I would just cut it myself and see how it came out.
Originally, I wasn't going to mess with the OEM portafilter. However, after some research on-line (and in speaking with Doug from OE on here), I came to the conclusion that the portafilter which came with my machine probably wasn't originally from La Pavoni anyway. As such, I decided "what the heck" and figured I would try my hand at the DIY naked portafilter route tonight. I'm happy I did, because the end result came out absolutely beautiful.
The entire job took approximately 90 minutes, but that's largely because I took my time and wanted to make sure it came out extra nice. Below are some of the better photos that I snapped along the way. I haven't pulled a shot using it yet, but when I do, I will be sure to follow up with some additional pictures here. I may also modify the handle a little bit, although for now I'm just using the standard handle that came on the portafilter.
Enjoy the photos and if anyone has any questions, please feel free to post them here. Thanks!
Ray
Here's the portafilter in the vice
As luck would have it, I just happened to have a 48mm bi-metal hole saw handy (1 7/8")
Here you can see the start of the cut. I just used a hand drill for this and it worked fine
Almost through the bottom after only about 5 minutes of chipping and cutting
Here you can see the progress. I stopped just short of going all the way through
Bye bye bottom! :-)
Not too shabby for a hand drill and a hole saw!
I used to port cylinder heads using this bit, so I'm pretty sure it can handle a brass portafilter
After doing a little blending with the die grinder
Checking to make sure we have consistent width front to back and side to side
Time for some further blending & smoothing with the trusty sanding wheel
Post sanding. As you can see, things are starting to take shape pretty nicely!
Now time for some polishing
Doing some polishing inside the portafilter basket area
After the initial polishing
This is after using some 600 & 1500 grit sand paper in order to produce a more satin finish
Here you can see the radius on the bottom edge
All done! Just needs a little further cleaning
A quick self portrait with my little brass masterpiece :-)
After washing in the sink with soap and water - looks pretty good no?
Here's a shot showing how it sits on the edge of the counter (complete with my 49mm SS tamper)
And here is the final result, locked into the La Pavoni & ready for extraction
RayJohns
Postby HB on Mon Sep 27, 2010 8:21 am
Beautiful work!
Postby fastbikes16 on Mon Sep 27, 2010 9:48 am
That looks great!! Now I am really tempted to try it for myself :lol:
Can't wait to see some shots from this beauty!!
Scott
LMWDP #306
fastbikes16
Postby RayJohns on Mon Sep 27, 2010 11:43 am
Thanks Dan! :-)
Scott - I did some test pulls just now, but they were all over the map. I think mainly because my beans are old and also because they are not specifically an espresso blend. I was out of town for a month, so most of the beans I had in the house are probably 6 months old or more. As soon as I have a chance, I'm going to head down to the local coffee roasting place and pickup their espresso blend as well as some green beans to roast here at home. I may also look into ordering some beans from on-line.
If anyone has any suggestions on beans, I'll be happy to try them! :-)
Ray
RayJohns
Postby RayJohns on Mon Sep 27, 2010 12:22 pm
Okay, I did a couple of quick pulls. Here's the only half way decent one. As mentioned in the video description (on youtube), I only had old store bought beans in the house. I'll buy an espresso blend and/or roast up some beans shortly here and do some more testing. However, for 9 month old Peet's coffee beans, this actually didn't come out too bad - all things considered. Anyway, you get the idea.
Oh and the lighting was all fouled up, because the sun started coming up while I was filming. Future videos will be a lot better!
RayJohns
Postby RayJohns on Thu Sep 30, 2010 6:44 am
Here's a better shot, using a very light tamp as a test.
Enjoy the video! :-)
Ray
RayJohns
Postby fastbikes16 on Tue Oct 05, 2010 8:45 pm
So, I was tempted enough to try this for myself and I think it turned out quite well! I used the same exact proceedure as Ray used, and although mine didn't turn out as well cosmetically, it works great! Here is a video:
LMWDP #306
fastbikes16
Postby RayJohns on Tue Oct 05, 2010 10:37 pm
Not too bad! :-) I think maybe just a slightly finer grind or a slightly harder tamp? It looked like it pulled a little fast. How was the taste?
Ray
RayJohns
Postby fastbikes16 on Tue Oct 05, 2010 10:45 pm
yeah, it was a little bit on the normale side of things, but the best shot of the day! I still need to practice my distribution more, as I am getting some channeling on some shots. Great to know now that I chopped my PF!
Scott
LMWDP #306
fastbikes16
Postby RayJohns on Wed Oct 06, 2010 5:12 am
I was having channeling problems as well. Try doing a lighter tamp and a little pre-infusion and see how it goes. If the coffee runs out too fast, then just make the grind a bit more fine until you get a good extraction. Usually the channeling is due to something being wrong as far as the tamping goes (usually too hard) or the grind. The water can't get through the coffee like it wants, so it has to dig a path through whatever the weakest area is.
The pre-infusion (combined with a bit lighter tamp), also the coffee grinds and water to mix up a bit first, then (after the pre-infusion), you start pushing everything through the screen in the group head. As long as the grind is not super fine or super coarse, then using that method usually makes a big difference.
Ray
RayJohns
Next
