Yes, it's the large brass ring with the 3 screw holes in it. It needs to be pretty tight to keep the boiler from turning in the base. The reason is because you have a lot of leverage with the handle, so it doesn't take much to cause it to turn.
On my machine, I installed two gaskets also (one on each side of the base). OE sells a nice tool which grips the ring at 3 points. You need to use a rather long ratchet (and their tool) grab the ring properly and to apply enough torque (while holding the boiler and base in place). If you tighten it hard enough, then nothing will move.
The first time I assembled my machine, the ring was tight, but not tight enough to keep the boiler from turning in the base. I had to take everything apart again and retighten it. Incidentally, this caused the ring to move about 1/2 inch further around, which moved my little chassis grounding screw further clockwise. Luckily, I was able to re-route the ground wire and still connect it. However, due to the exact/custom wiring I did on the machine, I'm glad it didn't move 3/4 of an inch
Just off the top of my head, I would say you need to apply about 20 to 25 ft lbs of torque (using the OE tool and an extended 3/8 ratchet or bar) in order to really secure things enough using that large brass ring.
Ray
