In my experience, maintaining the proper temperature on the La Pavoni can be pretty tricky (especially with the older I/II switch models, where you don't have the luxury of a pressure stat). In fact, as some of you may know, temperature control (or the lack thereof) drove me to install a PID controller on my machine. I found this not only to be a big improvement on the La Pavoni, but it also allowed me to clearly see that boiler temperature and boiler pressure are tied together, very closely, at all times. In fact, the correlation is so direct that, by simply using the chart provided here, you should be able to surf the temperature on your machine to within 1 degree.
Naturally, this chart doesn't speak to the temperature differential between the boiler and the group head, but it at least will help you get in the ball park as far as where the boiler water temperature is (assuming you have a pressure gauge installed, of course). In the future, I do plan to rig up a thermocouple into the portafilter basket, also. Once that is functional, I may come back and produce a chart showing the temperature drop between the boiler and the group head as well.
For now, however, I give you the following chart, which shows the water temperature inside the boiler, based on the pressure shown on the gauge. This data was taken from my La Pavoni Europiccola, which has a PID controller installed on it. Naturally, your mileage may vary, but I think it should apply pretty closely for most users.
To produce the chart, I increased the temperature on the PID controller by two degrees at a time and then allowed the machine/temperature to stabilize for a few minutes (before taking a reading and going up to the next highest temperature - 2 degrees at a time). Please note that my machine does have an adjustable pressure regulator on it (which may slightly impact the data), although I don't think it should have too much effect as compared to a "stock" La Pavoni.
The above temperature readings are from an RTD sensor, which is installed through the base of the boiler and which is in direct contact with the water inside the machine.
Anyway, if you are attempting to temperature surf (and have a pressure gauge on your machine), then the above chart may serve to be a handy reference. Usually, I run my machine at 232.0 degrees to 233.5 degrees (depending on the coffee bean being used), which seems to work pretty well for most medium roast beans. Keep in mind, also, that this chart was produced at approximately 800 feet above sea level.
Ray
