Anvan wrote:So thanks Ray, and I look forward to seeing what's next.
I've been talking with DrGary about installing a TC or RTD sensor into the bottom of the portafilter basket. As you correctly point out, the temperature differential between the boiler itself and the group head affects the water quite a bit.
It's like heating water in a pot to a specific temperature (not much of a problem), and then dumping the water onto your kitchen floor and hoping to be able to always achieve the exact same temperature when the water is on the floor.
Nevertheless, I think it would be interesting to install a TC into the basket and start taking readings. Since the La Pavoni I use does have the PID controller for the boiler, I think it would help highlight what sort of temperature drop there is. My thinking was to pull 10 shots in a row (which would [should] steadily increase the group head temperature). A graph of this might help show whether or not the group head reaches a plateau with regard to its temperature and whether or not this might have a stabilizing effect when it comes to how much of a difference there is between the boiler and the group head (i.e. water temp when the water is actually doing the extraction).
My gut feeling, after using the machine for a number of months, is that once the machine is up to temperature and the group head is hot (via pulling a few shots), there will probably tend to be some amount of stabilization that naturally occurs. This may be more true due to the PID controller, since it keeps the boiler temperature pinned down by about .1 degree. This being the case, I think the boiler (and the water) may tend to help regulate the group head temperature (once it's up to temp). If that's the case, then I would think the temperature drop that occurs from the boiler to the group head would be fairly predictable.
Right now I'm rebuilding the suspension on my motorcycle, so the La Pavoni "group head TC" project is down the list a bit
Anyway, I just thought the chart might be helpful to people who have a gauge and may have some interest in where the boiler temperature is. If you want to use a calculator to compute the boiler temperature instead, don't let me stand in your way
Ray
