Just received my 1991 Olympia Cremina - Page 2
Postby Avi Fischer on Sun Apr 02, 2006 12:06 am
I agree the color is very Italian.....I love it..even though I think it might look better in the Brady Bunch Kitchen....remember that reddish-orange formica.....some people are saying that those colors are coming back :D ........
Avi Fischer
Postby srobinson on Sun Apr 09, 2006 3:20 pm
Looks great....goes with your other high end appliances. Wife is redoing the kichen....so new appliances cohabitating with the Oly was key.
Steve Robinson
LMWDP #001
srobinson
Postby Avi Fischer on Sun Apr 09, 2006 7:27 pm
The Oly is very comfortable in our kitchen. It is surprisingly compact, does not really occupy more of the counter-top real estate then the Europiccola did. The problem is that now my appetite is whetted and I have been staring at a mini Mazzer (I am using a Gaggia MDF). I have been using Espresso Authentico with the Oly, trying to find the right combination of tamp, grind and pull. My shots are not ready for public view, although the Oly produced better results for me right from the start, I think the temperature is more stable and it is somewhat easier the apply steady pressure on the lever. In fairness to the Pavoni, I was really not aware of all that I have learned since finding the HB site, so maybe when I finish restoring the Pavoni I can do some honest side by side comparisons, and let people know what an amateur lever puller (I don't want to dignify my self with the word Barista) can expect out of these machines.......
A question: is there a consensus regarding what tamper works best with Oly? (flat or convex?)
Avi Fischer
Postby srobinson on Sun Apr 16, 2006 10:28 pm
Avi Fischer wrote:A question: is there a consensus regarding what tamper works best with Oly? (flat or convex?)
I like a flat. I have both a 48 Reg and a custom made thor that both do the trick will a bit different technique on the smaller size.
Steve Robinson
LMWDP #001
srobinson
Postby Avi Fischer on Sun Apr 23, 2006 4:46 pm
I just received and started to use the flat RB tamper. This is real help.....the weight and fit really helps me get a more even tamp and as a result my shots are much improved........I'm ALMOST ready to go public with my shots.. :D ..Thanks for all your help....next will be a question of whether to upgrade the Gaggia MDF.....I noticed that you use the Rancilio....if its good enough for you.....it is significantly cheaper than the Mazzer or even the Macap...
Avi Fischer
Postby srobinson on Sun Apr 23, 2006 8:21 pm
Dan keeps cracking on my grinder, but it does a great job for me. Also being on the HB team I get to test out alot of grinders which helps calm my upgrade fever down. What I really like about the Rocky is the compact size. And that Versalab.....
Steve Robinson
LMWDP #001
srobinson
Postby espressme on Sun Mar 02, 2008 12:49 pm
Congratulations!! Lovely!
Cheers
rp / espressme
richard penney LMWDP #090,
espressme
Postby IMAWriter on Sat Mar 22, 2008 2:50 am
srobinson wrote:Dan keeps cracking on my grinder, but it does a great job for me. Also being on the HB team I get to test out alot of grinders which helps calm my upgrade fever down. What I really like about the Rocky is the compact size. And that Versalab.....
Slight OT...apologies to Avi...Steve, the Rocky DL is a terrific grinder...too bad with that little basket you can't do the WDT...or can you...do they make yogurt cups THAT small?
Avi...your machine is beautiful. Enjoy it in good health!
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby espressme on Sat Mar 22, 2008 11:45 am
Hi,
I found that the plastic condiment cups from fast food Taco joints work quite well. Just cut the bottom out of the two ounce plastic cup and Voila!
Cheers
Richard / espressme
espressme
Postby IMAWriter on Sat Mar 22, 2008 3:40 pm
Avi Fischer wrote:I just received and started to use the flat RB tamper.
Hi...I just got a picture from Reg of my soon to arrive 51mm...I decided to try his newest piston...a hybrid they call "C Flat'...as a music guy, that struck a note...(sorry)
It's a combination for flat and concave surface!Image
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Previous
