by peacecup on Fri Aug 19, 2011 3:45 pm
I just fill the diouble basket to very near the top - between 14-16 g, depending on the type of beans. Also, I don't use the "no-tamp" method. I find that a comfortable light tamp, maybe 5-10 lbs, keeps the puck intact during the pull. If you go for a full basket and a light tamp, and it chokes the lever, back off a notch on the grind and you should be there. If you do the same and it drips coffee through the puck even before you let the pull begin, tighten the grind.
General procedure:
1 Prepare puck while machine comes to temp.
2. Let off false pressure, wait a few seconds until ready.
3. Insert PF, slowly pull lever down, and wait about 10 sec (if you get coffee dripping through, the grind is too coarse or the beans too old).
4. Slowly let the lever rise until the spring takes over (if it shoots upward, too coarse, if it stalls, too fine).
5. With the proper puck preparation you can take a second pull for a double.
With a little practice you can add a "Fellini" pre-infusion, but I would hold off on that for now.
It could be that your p-stat is set either too high or too low. When the machine is up to temp is there a LOT of steam (too high) or barely enough to steam milk (too low). Too high will result in brew temps that are too hot, too low, too cold. You can also do the finger-touch method on the group. If it burns, it could be too hot.
PC
LMWDP #049
