by peacecup on Mon Oct 17, 2011 3:06 am
15g is right on for a two-pull shot. I often go 16g. But each coffee has a different weight:volume ratio. Some 15g doses will top it out, other coffees can take 16g or more. Depends also on the grind and tamp.
Since I've been using the bottomless PF I find it takes a little fine-tuning of the grind to get a perfect cone extraction. Small variations in dose or grind can lead to extractions that don't look perfect. But they taste great anyway, so I'l let taste be your guide.
In simple terms, if find it easiest to dose consistently full, then adjust the grind to get perfect flow. For my tastes, perfect flow means: 1) One 10 sec preinfusion with the lever down, followed by a slow 1/2 rise of the lever 2) when one drop of coffee falls, a second pull down, wait 3 secs, then another 1/2 pull - some coffee will flow slowly, 3) a third pull down, 3 sec wait, then the full pull. The coffee pours in a perfect cone from the basket.
LMWDP #049
