Long before I posted for the first time on the HB forum, I've wondered about how it would be to make espresso on a lever machine, never seen one close up much less had the chance to use one.
This afternoon I came across this little thing (for a nice low price) and promptly snapped it up.
From the sellers (bad) photo, I think it has had little use.
Edit: new photo placed inline.
It seems to be a Pavoni and even has a red sticker that clearly says 'Pavoni Shirley' and 'Industria Argentina', meaning that it's been made or assembled here in Argentina, of all places.
The problem is that I cannot find any references to a Pavoni lever model called 'Shirley' or any Pavonis made or assembled outside Italy.
I will be taking possession in a day or two, so I'll have better photos to show the forum.
Edit: New information.
I have found Shirley to be in excellent shape and dare guess that if it has seen any use at all it's been no big deal. The boiler holds ~ 1.20 litres when filled up to the 'shoulder' and shows no signs of scale. The cap's seal seems to be in perfect shape.
Edit: Updated information
The total capacity of the boiler is ~1.50 litres, filled to the brim.
The 52.0 mm portafilter is also in perfect shape, with no sign of wear and tear or stains and the same can be said for all the plastic parts, handles and knobs. It came with two SS baskets, both 23.0 mm deep.
Austin Powers wrote: [In a PM]
I suspect you have a misunderstanding as to how group size is measured. The accepted standard is to measure the inside diameter of the coffee filter, not the filter holder. Thus when people speak of "a 58mm group" they mean the the coffee filters measure 58mm across the inside.
Italian made Pavoni home lever machines have a 49mm group from their inception until the start of the millennium group, which is 52mm nominal.
Then this Pavoni 'Shirley', measured correctly and not my way, has a 49.0 mm group. =-)
The drip tray grill is plastic and there's a plain on/off switch with a neon lamp indicator but no fuse or temperature control, it's wired direct to 220v. I cannot find any indication as to the wattage of the resistance.
The wattage of this 220v heating element is 800W, ~ 60 Ohms across posts.
Anyone have any idea with respect to this Pavoni model or to what model it could compare to?
Thanks in advance,
CIV
