Is this glue on the group?
Hi, I was recently given a 2004 Europiccola for parts from a friend who said he'd stopped using it several years ago due to leaking out of the group. So when I unscrewed the group from the boiler, I came across this on the backside, which looks like glue. It's is rock hard. I've disassembled two other La Pavonis recently and definitely didn't come across anything like this. Thanks. Matt
Looks like the machine has boiled dry at some point and melted the O-ring and gasket.
Ahhh, ok, thanks. I'll try to chisel it out of there.
- homeburrero
Here's what it's supposed to look like:
It's possible that the siphon tube broke on that machine and that someone tried to be creative and glue it in. Once you dig out the old black plastic insert (it's threaded into the group) you'll need a new insert and a new o-ring. You can get both from Stefano's espressocare. Take a good look at your siphon tube - there's a chance you need that also if the old one is broken off.
Pat
- nickw
Yes. Your best woodworking chisels are probably the ideal toolfunkmusic wrote:Ahhh, ok, thanks. I'll try to chisel it out of there.
- homeburrero
Since the plastic insert piece is screwed in, and you aren't trying to salvage it, you might want to try drilling two holes at opposite sides of the insert (not too close to the edge - you don't want to damage the threaded brass), then thread a couple screws into the two holes, then clamp those screws in a vice. Turn the group CCW with the two screws firmly locked in the vice jaws.
Pat
It's definitely Gorilla glue. The siphon tube looks fine actually, and threaded but it won't screw into the plastic insert after I scraped out the glue. I think the plastic threads or too worn, so this piece will need to be replaced. Many thanks.
