Is Ponte Vecchio Export Steam Wand Moveable?
minniemousey
#1: Post by minniemousey »
Hi there,
I'm the proud owner of a PV Export and am just getting properly acquainted with it.
I was under the impression that the steam wand was fixed however, my steam wand moves up and down. Is this the case for others? Am I damaging the seal/valve inside the wand by moving it? I have been moving it up to bleed off the false pressure and back down again to steam the milk.
Many thanks.
peacecup
#2: Post by peacecup »
That means that the locking nut is not fully tightened. You should find the angle that you like best and tighten the nut.
With just a little practice you'll find the fixed-position wand is still great for steaming - you just need to position the pitcher in the correct place.
PC
LMWDP #049
minniemousey (original poster)
#3: Post by minniemousey (original poster) »
Thanks PC. I was hoping you could shed some light here! Your yearly reviews of the Export helped convince me to buy one :D
The positioning of the wand doesn't bother me but it was handy to move it when I was bleeding the false pressure off.
Thanks again!
