SlowRain wrote:I can't answer your question because I have a Professional and not a Europiccola. However, there are some steaming difficulties with the Pavoni that you may not be aware of, especially coming from the Silvia. The three-hole nozzle on the Pavoni isn't easy to get great microfoam from. Some people insert a toothpick or something similar to block two of the holes. One of the members here on H-B has created his own single-hole nozzles (Milk Frothing / Steaming on La Pavoni Europiccola - Modified Steam Nozzle). I haven't done either of these options yet, so my steaming is subpar for now.
Good luck with the Pavoni. Just don't put too much pressure on it when you push down on the lever.
Hoenen wrote:Im interested in acquiring a La Pavoni, but still undecided between the Europiccola and the Professional. I understand that the Professional will have more steaming power because of its larger boiler. I usually make double cappuccino's (me, spouse) with my Silvia and have found no youtube video where they steam the milk for a double cappuccino (which is what, 9-10oz, 300ml?), just singles... Any thoughts?
hperry wrote:You would do better steaming with a Ponte Vecchio Lusso or Export, although I know that it is not the same type of lever.
SlowRain wrote:Are you planning on getting a chrome or brass Europiccola? I'm curious to know if anyone makes brass nozzles.
