timo888 wrote:The term underextraction might mislead some readers; it has negative connotations and is therefore not the most apt word to describe the extraction gradient when water under 6 bars of pressure passes through a tallish, narrowish cake of coffee as opposed to a shortish, broadish cake of coffee (i.e. 45mm tall basket versus 58mm broad basket). In the taller narrower cake, the coffee cake may undergo less extraction but the espresso produced is not underextracted in the pejorative sense.
Brew ratios are dependent upon a number of factors, including but not limited to depth and freshness of roast, type of bean and bean processing, dose, grind, tamp, temperature, preinfusion, and brew pressure -- and so it is best not to draw general conclusions from a limited range of very loosely controlled experiments. But I think one can say fairly safely that with 6 bars of pressure and taller baskets it is easier for the barista to avoid overextraction and the harshness that accompanies it.
Regards
Timo
Excellent clarifications! I use words like under-extraction, because I am borrowing from what Jim and Andy have been doing, and prefer to use the terminology that they are using, in order to minimize confusion. I agree that the term might imply to some that shots are deficient or unbalanced in some way, which is simply not the case.
re: brew ratios - I submit that the water volume of the shot is the single greatest determinant of this ratio. Therefore, I suspect that your variables selection may be more true for non-spring levers than spring lever machines. Given that 2 pulls will consistently give 30ml of water, there will be very little variance in brew ratios from a spring lever machine based on much other than dose. I know that using Andy's strict definition of brew ratio as the dry weight of the puck to the weight of the resulting shot, it is a huge challenge to produce anything with more than a 50% brew ratio on the PV. This falls on the low side of the brew ratios that I get from my Brewtus II, presumably because of the higher pressure and faster extraction rate of the pump machine and 58mm basket. I'm not sure what to make of brew ratios and the PV group, since my 50% Export shots are every bit as deep, rich, and full as the higher ratio shots I get from the DB, and certainly moreso than an equivalent ratio (45%-50%) shot from the DB.
I have tried several 13-14gm doubles on the Export over the past day. Squeezing 14gm into that basket is an art in itself, and I suspect that without doing some mid-tamping or serious PF tapping, I can't get much more than 13gm into the basket. What's interesting is that at 13+gm, there is no sign of brew-screen collision on the top of the spent puck, so the basket can certainly handle that amount. The shots have been...delicioso (thanks again PC). I mean seriously snacktacular shots (using both my home blend and Sweet Maria's Yemen San'ani). Regardless of whether the dose is 11gm or closer to 14gm, I now am convincing myself that the 45mm basket's tendency to extract slower (or less, ie. under-extract) can be offset by a faster pull to get a traditional-style shot. As Jim mentions in his paper on extraction, and is clear when brewing, a faster flowing shot will lead to a higher extraction rate. Based on this, and on the look and taste of the Peacecup-style shots, I think that for my taste and coffees, the best (richest, most balanced) shots are those where the pull does not slow to a creep (maybe 8-15 seconds, rather than 15-20 seconds). That is, the deeper column of coffee in the PV double basket benefits from a faster flow rate to get a 'traditional' extraction.
I'm learning that the PV is capable of producing a wide variety of shots, and that the range of shots rarely falls below the level that an espresso lover would consider 'very enjoyable'.
Mark
