Initial Impressions of the Ponte Vecchio Lusso - Page 5
Postby timo888 on Thu Mar 29, 2007 8:00 am
Kaffee Bitte wrote:That is a beautiful shot. Just wondering about something I have seen a few times with Ponte Vecchio shots. Why is the shot mostly pouring out only one of the two holes? Is the machine not leveled properly or is this just a peculiarity of the portafilters?
I think there was a huge meteor passing near Earth's orbit, which warped the gravitational field and dragged the cone off-center. :shock: Certainly not to be explained by imperfections in barista technique. 8)
Regards
Timo
P.S. The Rocket Dark Star was roasted on the 19th of the month and was 9 days old for this shot. Aromatic, mellow, sweet.
timo888
Postby peacecup on Thu Mar 29, 2007 1:09 pm
Timo wrote a while back that there was a chip off the chrome on his Lusso:
perhaps the enameled panels would be a better choice, if they are available.
My Export is painted, and it also had a small chip when delivered. The enamel can also chip where it is constantly being brushed against, such as under the filler-cap cover on the Export. I just put a drop of olive oil on the metal occasionally to prevent rusting, but it will be simple to prime and touch it up.
Also, someone asked a while back about the 45 mm baskets - I consistently dose 15g into my double basket with sufficient headroom, and pull either two-pull (1oz) or three-pull (1.5 oz) ristrettos. The "official" dose for a 2 oz doppio is, I believe, 14g, so the former are "official' ristrettos. One can adjust all factors and get a 14g, 2-oz doppio with the Ponte Vecchio, but it takes practice and it may not be optimal.
I've been focusing on 15g, two-pull, 1-oz ristrettos lately - these are quite intense - that's a lot of coffee for 1 oz of water.
I posted a 15-g 1-oz, 90% crema video yesterday:
http://www.home-barista.com/forum...o-t3687.html#39425
Looking forward to the dinner party review!
PC
LMWDP #049
peacecup
Postby peacecup on Thu Mar 29, 2007 1:13 pm
Oh, and re: the single stream from the PF, this is due to the way they are machined - if timo can post a photo of the inside you'll see that the coffee could easily flow all one way or the other if there is the slightest lean on the machine - I don't think this reflects uneven extraction. In fact, since about the second day I used my Ponte Vecchio I have never seen any evidence of side-channeling, especially with the double basket - the tall, narrow design of the 45-mm basket makes dosing fairly foolproof.
PC
LMWDP #049
peacecup
Postby Dogshot on Thu Mar 29, 2007 2:39 pm
I notice a few differences between the shots Peacecup is posting and the one Timmo has posted. The Peacecup shot has more crema that lasts longer, and the shots are being extracted in 6-8 seconds pulls (12-16 second total extractions), whereas the Timmo shot is extracted in 12-15 second pulls (24-30 second total extractions, assuming dwell times are equivalent between the two styles). I see that Peacecup is using 15gms in the double. Timmo, how much coffee are you using in the double?
I have tried to replicate both styles of shot on my Export. My customary pull looks more like Timmo's shots, which seem to pour as crema which dissapates quickly, leaving only a thin layer. I use 11gm in the double basket and to get a shot more like PC's, I back off the grind by a .5 turn on my Macap (which corresponds to about .3oz difference in shot before blonding on my E61). The coarser grind leads to a quicker shot, but this shot has more persistent crema and greater mouthfeel. It is also not as sweet or smooth as the finer, longer shot.
I believe that this makes sense in light of Jim's recent work on extraction ratios. The same volume of espresso pulled from a coarser grind in a shorter period of time should extract less than one pulled from a finer grind over a longer period. Also consistent with what one would expect from an E61, a similar volume pulled from a larger amount of coffee will have greater mouthfeel, and emphasize the chocolates and bitter flavours, whereas the lower dose will have less body and greater sweetness.
So, in my experience, I would say that Peacecup's shot is a lower extraction shot than Timmo's. On my blend, the PC style shot certainly has more of the cocoa notes and mouthfeel, whereas the Timmo style shot is a sweeter, milder experience. As you suggest, Peacecup, I would agree that you are pulling ristrettos compared to Timmo's normales. Does this make sense, or agree with both your assessments?
I really enjoy both styles, and it probably would not have occurred to me to try to get a PC style shot had you not posted it.
Mark
LMWDP #106
Dogshot
Postby timo888 on Thu Mar 29, 2007 3:38 pm
Dogshot wrote:Timmo, how much coffee are you using in the double?
11 ± ½g
The shot in the video was 11g.
I'm happy when the crema clings to the inside wall of the cup.
Regards
Timo
timo888
Postby peacecup on Thu Mar 29, 2007 4:43 pm
I have come to understand that 14g- 2.0 oz is a normale. You need to take four pulls to get 2 oz on the PV. Mine are 2-or 3-pull ristrettos as I understand it. Timo's dose falls somewhere between the traditional 7-g single and 14-g double. I tried down-dosing after reading Jim's paper, but I don't really like the way the puck performs (seems to be less firm at removal, suggesting channeling), and I'm not sure his theories of extraction really apply to the 45-mm basket and the 2- or 3-pull technique. I'll need to experiment a bit more with it. Its very interesting how one can produce such different types of shots with one simple little espresso maker.
PC
LMWDP #049
peacecup
Postby peacecup on Thu Mar 29, 2007 4:44 pm
BTW, the 14-15 g pucks invariably pop out of the PF as a dry, solid puck.
LMWDP #049
peacecup
Postby Kaffee Bitte on Thu Mar 29, 2007 5:21 pm
peacecup wrote:Oh, and re: the single stream from the PF, this is due to the way they are machined - if timo can post a photo of the inside you'll see that the coffee could easily flow all one way or the other if there is the slightest lean on the machine - I don't think this reflects uneven extraction. In fact, since about the second day I used my Ponte Vecchio I have never seen any evidence of side-channeling, especially with the double basket - the tall, narrow design of the 45-mm basket makes dosing fairly foolproof.
PC
I figured it was one of these interesting quirks that lever machines are so lovely about. Must be nice having the depth to not have to worry about dosing. I know that it can be a huge pain in 58mm pf's. The portafilters I use at work can be pretty picky. It sometimes seems like all of my shot preparation time goes into just the pretamp prep.
Lynn
Kaffee Bitte
Postby timo888 on Thu Mar 29, 2007 5:57 pm
peacecup wrote:I have come to understand that 14g- 2.0 oz is a normale. You need to take four pulls to get 2 oz on the PV. Mine are 2-or 3-pull ristrettos as I understand it. Timo's dose falls somewhere between the traditional 7-g single and 14-g double. I tried down-dosing after reading Jim's paper, but I don't really like the way the puck performs (seems to be less firm at removal, suggesting channeling), and I'm not sure his theories of extraction really apply to the 45-mm basket and the 2- or 3-pull technique. I'll need to experiment a bit more with it. Its very interesting how one can produce such different types of shots with one simple little espresso maker.
PC
Illy's single is as follows:
Volume: 25-30ml
Ground coffee portion: 6.5 ± 1.5g
Water temperature: 90 ± 5° C
Inlet water pressure: 9 ± 2 bar
Percolation time: 30 ± 5 seconds
My two-pull double on the Lusso was slightly updosed, by Illy's traditional standards*.
Regards
Timo
P.S. Do not fear a goopy 'puck'.
*A 30ml espresso from an 11g dose on the Lusso, even with the spring-lever's somewhat lower brew pressure which is also tapering off during the pull, is ristretto in its flavor-intensity. For a ~30ml normale, one could lower the dose by a couple of grams and use a slightly finer grind.
timo888
Postby Javier on Thu Mar 29, 2007 6:54 pm
Hi Timo,
Great job reviewing the PV Lusso. Two questions:
1. Is it possible to replace the spring with one that will allow the owner to pull a shot at ~ 9 bars (i.e., thicker spring and/or more coils)?
2. Will it be possible to replace the steam wand tip for an aftermarket tip (e.g., three-hole, two-hole, etc.)?
Thanks!
Javier
Javier
PreviousNext
