jmequipe wrote:Hello timo
At this time, i've only one single basket. Next week, i'll buy a double basket in UK.
I'm going to buy also a grinder like the Rancilio doserless ( what do you think ?) because i think it will be better
to do the job mysef instead the coffee shop. they don't find the good grind for my espresso machine.
Anyway, the pressure of the machine is only 1 bar and i think to myself that is a little bit low ?
Maybe 1.2 will be a good choice.........i'm going to change the rate today if i can.
sneakymagic wrote:My this thread has moved on since I went away!
Some extra info on the Sama variants-
and with apologies for adding this quite late in the day - Vis comparisons of springs and pressure generated a couple of caveats: my Sama could be anything up to 20-25 years old so over that time I would expect that different spring batches would be ordered/supplied which could easily lead to differences in bar within the SAMA performances - less likely for the PVs as they haven't been around under that name for the same amount of time. Plus, who's to say I have an original spring as the machine is at least 2nd hand, and quite probably more?
You may also find these models under the name Musette (slighty prettier finish with water/steam knobs front located, though I've only seen one such).
Be aware also folks that older Sama "Lussos" have a Bezerra-alike grouphead, complete with bearing mounted lever arm (Peacecup tipped me off on this and I've seen photos of a couple of examples), so who knows what parts were borrowed/canibalised etc in the transition phase.
mgwolf wrote:You've had your Lusso for about 2 months now. Any further, up to date impressions? Are you still happy with it? What's your current impression of the ease/consistency of pulling good shots? Does it still compare favorably to the Cremina? Steaming issues? Any annoying aspects?
