I've been enjoying this discussion of the Lusso. I have a different question for you. With pump machines, much fuss and energy is expended with the temp adjustment to get the best out of various coffees. From what I can tell, although the Lusso has a pstat, no one seems to fool with it much. Also, unlike and HX, the grouphead seems to give a very constant temperature when pulling shots. Soooo.... does anyone readjust their pstat for different coffee blends, or more important, feel the need to? If not, why not? Is everyone getting delicious enough shots all the time that they don't feel the need?
mgwolf wrote:With pump machines, much fuss and energy is expended with the temp adjustment to get the best out of various coffees. From what I can tell, although the Lusso has a pstat, no one seems to fool with it much. Also, unlike and HX, the grouphead seems to give a very constant temperature when pulling shots. Soooo.... does anyone readjust their pstat for different coffee blends, or more important, feel the need to? If not, why not? Is everyone getting delicious enough shots all the time that they don't feel the need?
mousetail wrote:Outer diameter of spring 35mm
Length of spring 73mm (although the new repacement was about 3mm longer*)
Thickness of wire 5.5mm
Number of active coils (excluding the filed down ones) 5
Distance between coils 13mm (possibly slightly more on new one*)
Bob
Pixelator wrote:While on hiatus from the board over the past several months, I've been saving for a Lusso. Your review convinces me that I made the right choice and that the Lusso is the best value in a new lever machine. The bad news is that what I've saved so far is being re-routed to the Feds in a couple of weeks.![]()
Thanks again for the great review!
timo888 wrote:[snip]
I have been experimenting with dose and grind on both the single and double baskets. With a lower or higher dose, 5g-7g in the single basket, 10g-14g in the double basket, and an appropriate grind, the Lusso can produce a wide range of espresso, a tight ristretto's spicy intensity, a lungo's clarity and floral delicacy, a normale's smooth cocoa and sweet caramel.
[snip]
Regards
Timo
Pixelator wrote:Have you posted the procedures of your experimentation and the corresponding results anywhere? I'd like to read them if you have.
