Bluecold wrote:I've never heard of such a beast. I've thought about making a new group bell ring to accept PV portafilters, which are much nicer chromed brass, are available in bottomless and accept the same filters. The whole endeavor would cost about 100 Euro's (i figured at least 50 for the group bell ring and the PF's go for 50) and that was too much for me.
yakster wrote:I just picked up a La Peppina and am immediately missing the bottomless portafilter I was using on my previous machine to help me troubleshoot my technique. This thing is a whole different animal then my toy pump was, and I'm trying to dial in the grind, dose, tamp.
Does anyone have a bottomless portafilter for a La Peppina they'd be willing to lend? I could send it back with some locally roasted (or home roasted) beans when I'm done.
Thanks.
timo888 wrote:The Peppina's group and pf are made of aluminum for a good reason -- when the water leaves the boiler|kettle at the right brew temperature, not superheated, you don't want a big hunk of brass sinking heat away; rather you want metal that doesn't draw much heat from the water, such as aluminum or stainless steel.
yakster wrote: I don't think I've been preinfusing long enough.
Can you describe your method? I've been pulling down the handle, letting it rise up about 1/4 the way, and coming back down, but I should probably hold it on the second down stroke for longer. Maybe I should switch back to the double basket until I get more comfortable with this but I like the idea of the single basket so I can pull and try more shots in one session. I was really having much more luck with the double basket I started with.
If you pull singles, what's your target dose? I've tried from 6 to 7.5 g and I like the higher doses better.
I still would love to see a bottomless portafilter for this. If I ever go crazy and make one myself, I'll post to the forum about it, but I don't have any plans to do this in the near term.
-Chris
