If God wanted us to go naked, we'd have been born that way.
Postby RapidCoffee on Sat Jan 26, 2008 11:46 pm
Unfortunately my Gaggia Factory portafilter was not born naked. It required a bit of help from my machinist friend, Brett Wilsey:
It was fun to watch the master at work:
I think the surgery turned out really well:
Nekkid pours are not easy to photograph on a lever machine. Have you ever tried pulling down on a lever with one hand, using your other hand to stabilize the machine with an upward pull on the portafilter handle, while simultaneously crouching down and wielding a camera? :shock:
PT's Finca El Patio, a somewhat finicky SO Costa Rican.
Downdosing to 12-13g gave better results than 14-15g doses.
Brett has graciously offered to chop portafilters for the bargain basement price of $20.
Please PM me for further info (i.e., do not post asking for ordering information).
John
RapidCoffee
Postby prof_stack on Sun Jan 27, 2008 8:01 pm
RapidCoffee wrote:Nekkid pours are not easy to photograph on a lever machine. Have you ever tried pulling down on a lever with one hand, using your other hand to stabilize the machine with an upward pull on the portafilter handle, while simultaneously crouching down and wielding a camera?
Great photos and nice post. Brett might be a busy guy in the next few months.
Yes, I have tried to take photos while doing the other stuff and it isn't easy. You did well.
When you say 12-13g gave better results, what do you mean? Flavor, crema, ease of pull?
LMWDP #10
Hand ground, pulled down, best around!
prof_stack
Postby RapidCoffee on Sun Jan 27, 2008 10:00 pm
I've often enjoyed Costa Ricans for drip/press/vac coffee, but never as SO espresso. PT's Finca El Patio is a lovely surprise in this respect.
However, I found it a bit difficult to get really nice-looking naked pours, even on the Vetrano. I had problems with channeling and uneven extractions at higher doses. For whatever reason, a slight downdosing was the key to "pretty" pours on both my pump and lever machines. The taste seems improved as well.
This was a bit surprising, since I'd expect a SO to be easier to pull than a blend. But PT's Bella Vita espresso blend was noticeably more forgiving, especially of higher doses.
John
RapidCoffee
Postby Mike Panic on Sun Jan 27, 2008 10:21 pm
nice - im hoping my machine shop friend can hook mine up shortly
regarding costa rican - ive been pulling GREAT tasting shots with La Amistad coffee all week... luv the stuff in french press and my lever
Mike Panic
Postby Mike Panic on Sun Jan 27, 2008 10:24 pm
Mike Panic
Postby RegulatorJohnson on Mon Jan 28, 2008 12:23 am
how bout a tripod.. and the timer?
jon
jon stovall
coffeetoolsapp.com
RegulatorJohnson
Postby RapidCoffee on Mon Jan 28, 2008 2:23 am
RegulatorJohnson wrote:how bout a tripod.. and the timer?
That would be much too easy. :wink:
John
RapidCoffee
Postby Espin on Wed Aug 26, 2009 1:52 pm
RapidCoffee wrote:That would be much too easy. :wink:
Or a hi-res digital video camera, and extracting stills?
Espin
Postby JohnB. on Wed Aug 26, 2009 2:45 pm
I turned the stock p/f that came with my Microcasa a Leva into a bottomless p/f recently. No lathe but a 2" hole saw, die grinder w/1.5" cut off wheel & a hand file did the job nicely.
LMWDP 267
JohnB.
