by peacecup on Tue May 16, 2006 8:36 pm
I, too, use a German hand grinder, and I love the truly stepless adjustment. In fact, one of the most rewarding parts of the lever espresso experience is the minute adjustment that nearly always make the second shot better than the first. You've obviously got a good grasp on the main variables, although the espresso niche is truly an N-dimensional hypervolume. Here are some of my thoughts:
1. You'll be able to isolate the necessary grind adjustment better if your dose and tamp are as consistent as possible.
2. I find its nice to concentrate on one or two bean varieties at a time, unless I have a lot of time to experiment.
3. Keeping the lever pull technique constant helps, but of course a sink shot (or in my office, a window shot) can often be saved by adaptive management mid-pull (increasing/decreasing pressure).
Since I'm logged in I'll also add how pleasant it is to hold my grinder between my knees, and, with the hopper open, imbibe in the aroma of fresh beans being almost noiselessly ground to the exact fineness my Ponte Vecchio is silently awaiting.
Peace,
PC
LMWDP #049
