The_Mighty_Bean wrote: ... I start getting drips by pumping the lever arm about halfway through its arc.
timo888 wrote:If I understand you correctly, when you simply press the lever halfway down (i.e. not up and down in a pumping motion?) you start seeing drips in the cup before the lever rises? If so, make the grind finer.
For the residual water on top of the puck, though it is not a real problem, you could try lowering the dose to around 11-12g.
The_Mighty_Bean wrote:Thanks, both of you. I'll replace the outlet, and I'm being very careful with the thermometer probe placement. But don't you know, all I was thinking about was that if the probe touched the element I'd get a data error. I suppose investigator electrocution is the ultimate data error.
Regarding the lever, it does require a pumping motion. If I tighten the grind any more, it will choke. But-- when I take the lever down all the way once or twice, then the beginning of the extraction is too thin and dark brown.
If instead, I only take it halfway to 3/4 of the way and pump it, then I get visible crema when the extraction begins.
Does that make any sense?
The pucks are always a sort of formless mess. I read on another thread here that messy pucks could indicate a small washer issue. I'll also try a lower dose, but I don't think 11-12 g will reach the top of the basket, which makes levelling just about impossible.
~tMb
johhnyguitar wrote:When you get to rebuilding her, we have a step by step photo/text 'how to' Tech page that might help you out!
