Belbo wrote:1) There was no plastic wrapping around the machine.
2) There was no video or cleaning solution included in the pack (should there be one?).
3) The tamper had the oily feel that coffee leaves on it.
4) The cappuccino attachment had something like corrosion (on the chromium piece).
5) There was a bit of water inside the machine.
6) The portafilter had brass exposed in one (small) area. On this now, after 10 uses or so, brass is exposed let's say up in 30% of the portafilter area: is that normal?
7) The portafilter does not stop when inserted & turned by 45 degrees, but if pushed (quite a bit) can go up to 90 degrees (practically vertical to the lever): is this normal?
8 The lever has some flex right & left.
Belbo wrote:Dear all,
Super-excited I've ordered the machine online and waited for it to arrive. It did yesterday but unfortunately it pretty much killed my excitement: from the time I've opened the pack, the idea that the machine has been used stack to my mind, here is why: Peter
Peter
A2chromepeacock wrote:I'm glad you're relieved, but to be clear:
1. exposed brass is *not* normal, certainly not on a new machine. this should be addressed.
2. The portafilter shouldn't turn that far (if I am correct in understanding your description). Looking down on the group head, the portafilter handle points to 6 o'clock when first placed into the group, and rests at ~7:30 when fully locked in. Stated another way, a 45 degree clockwise turn should be all the further it goes.
Belbo wrote:7) The portafilter does not stop when inserted & turned by 45 degrees, but if pushed (quite a bit) can go up to 90 degrees (practically vertical to the lever
