How to remove gaskets from microcimbali
- algue
I think that you can do it with a cutter, trying to put the blade between the gasket and the metal and then trying to lift it
alberto
alberto
- drgary
My first try is with a picking tool. When restoring my Conti Prestina and facing fossilized gaskets Doug Garrott (orphanespresso) suggested using heat, i.e. a propane torch. But that was brass and this is aluminum. Maybe others can chime in. With brass if you heat it too much you can make it brittle, I've heard. If the picking tool doesn't get it I might try running a small part of it over a lit candle and see if that starts to burn off the old rubber. The heat wouldn't ruin your aluminum part (think of aluminum frying pans).
By the way, when tightening down the aluminum parts on your grandfather's Microcimbali, do not overtighten or you can crack the piece. I learned the hard way.
LMWDP#308
LMWDP#308
- orphanespresso
- Sponsor
Make a little chisel from a small screwdriver by using a grinder. You can then use a hammer with this chisel and break out one part of the old gasket...once you break out one section get under the rest of it with a pick and it should come right out. I use a dental drill also for this, or a dremel, but dental stuff is cooler.
Doug Garrott
www.orphanespresso.com
