1) I use a small screw driver to get the rubber gasket. It'll be easier to remove the gasket if you can remove the shower screen first but I don't have the tool to do that with the gasket in place, not enough space, so I prey the gasket out first. The shower screen is press fit on to the group head. You can see the lip of the screen.
2) After the screen is off.
3) Use a clamp compress the piston a little so there is no tension on the pin that holds the piston rod. Remove the c ring, make sure the clamp is secure so the spring does not jump out.
4) Slowly release the clamp now you can remove the piston.
5) The volume is pretty small for this group head.
6) There is only one water inlet in the chamber.
7) When re-insert the piston make sure the second seal counting from the bottom is properly fit into the chamber.
8 ) It's pretty hard to get the piston back in. The piston needs to go up pretty high so you can insert the pin back in. I use a clamp to compress it. There is not a lot of surface area for the clamp to fit securely. I had the clamp slip and all explode couple times.
After all is done now the piston is butter smooth again. Next step naked PF.
