Hi Guys,
Well, I've begun to notice a slight leak at the base of the nut on the sight glass of my early 1970s Cremina. I've checked with the back of the machine off and it seems the only place that has sprung a leak.
Now I realise that I'll probably have to change the sight glass seals, something that will require me ordering them from Orphan Espresso. (Damn, I just received my last order in the international post from them a few weeks back. Why can't everything breakdown at once?).
Anyway, before I change the sight glass seals, which Doug warns on his site is no easy job, I first want to try to tighten the nut. I can't really get at it easily from the back because of the pressure stat, so I want to get at it from the front. This requires the faceplate to be removed.
Tell me, is there any easy way to do this? I'm hoping there is an simpler way to do this than set out on Doug's site in relation to changing the sight glass seals
http://www.orphanespresso.com/Olympia-C...571-1.html .
I really don't feel like taking off the steam valve faucet, group et al just to tighten a nut. Must I?
Thanks in advance for any suggestions.
Robert
