peacecup wrote:... regardless of all the bantering, I still consider a 15-g, two oz. shot a doppio .
If you are going to use doppio instead of double you must state the volume in metric
Bantering,
Timo
peacecup wrote:For some reason I just can't bring myself to go to ml for volume, but I'll try.
peacecup wrote:I keep experimenting with different grinds/doses in the PV 45 mm basket, but I nearly always come back to the "maximum dose, finest grind" principle because I like the results in the cup. This principle holds that I fill the basket until there is just enough headroom for expansion, and grind fine enough to be on the razor's-edge of needing to apply a little extra pressure via the "leaner" lever override method.
