Thanks Doug for your quick reply.
Here is are some pics of my thermostatic safety switch:
So, Doug, you're suggesting that the safety switch is faulty because it didn't stop the machine from shorting. OK, so that means I probably need a new safety switch. But if it didn't stop the short circuit, then is it possible the heating element has gone as well? And other components on top of this. Is that what you mean when you suggest I should check out the machine with a manometer? Given my lack of knowledge in such matters I will have to get a friend to help me with this (and I can't even offer him one of my famous Cremina espressos as a reward).
As for the safety switch that OE sells (last pic above) do you think, Doug, that it will fit on the basis of the pics provided?. Will it fit in the hole in the base AND under the metal grate?
Thanks as usual for the help.
