Stash wrote:How can I remove the steam shaft tee to replace its seals, and perhaps pull the dent out a little?
You'll want to pull out gentle using the "tee" as leverage. Mine arrived to me pushed in when I received it from ebay and I was told to do the same
HERE.
Stash wrote:I can't figure out how to get to that nut under the boiler shoulder. Or should I just replace the seals and leave the ding well enough alone?
If you want to remove it, you need to remove the element and attack from the inside. With out having any replacement seals on hand, I wouldn't go this route. You will also require a box ended wrench with an offset handle.
Stash wrote:Leaves me torn between buying a portafilter and giving it to my son, or junking it. Oh, does anyone want to trade a pre-Millenium portafilter for a Millenium portafilter?
DO NOT JUNK IT!!! It can be fixed, especially if your problem is the same as mine in the link I provided (which wasn't a problem after all) And, depending on the price, I and a few others here may be interested in your pre-millenium portafilter.
