beansbats wrote:Good evening,
I have been following this thread for a while, because I also acquired an Amore on on EBay. The one I now have is similar to the one happytamper has, and is the spring lever version. So far I have been afraid to to pull a shot because after it heats up and as I pull the lever water squirts out of the hole on the back of the group head. Does anyone know what this hole is supposed to be for (It isn't diagrammed in the instructions)? I am afraid maybe I overfilled the tank.
Just because I am excited about owning the machine I have included a picture
Thanks,
Steve
Good find Steve, Thanks for the photo as there are way too many types on this thread for us to try to troubleshoot by name!
I have had two problems with mine. (big direct lever "Enrico")
1. The piston unscrewed and the upper seal got below the inlet..
2. A dry upper seal.
If the water came up the piston shaft, then I would suspect the piston rod seal.
Dow 111 on the seals did the trick for the dry upper seal. and a bit of Loctite for the loose piston.
Give thanks that your machine will be easier to get the piston out of and see what is going on!
sincerely
richard / espressme
PS, what size is your Portafilter?
