I am trying to rebuild an Astoria 2-group lever machine for a local restaurant. For what its worth, I am not charging them for my time. The main problem seems to be water leaking past the piston inside the sleeve. I have taken one group apart and tried to order parts from espressoparts.com. But, unfortunately the piston does not match the one they show in their online catalog. Devon referred me to General Espresso and they could only say it doesn't look like anything built since hey took over the business in 1995 - but, they will forward my pictures to the factory to see what they think - but, since its vacation time in Italy, they said it could be a few weeks to get a response. So, in the hopes of getting an earlier resolution, I have posted this here.
The big difference is that the piston I have has six white rings, not unlike piston rings on a car. Note the break in them (red circle) in the first photo below. I have included a picture of the espresso-parts piston with the gaskets they sell - you can see they are quite different.
I have also attached a picture of the group since it differs from the other more bulging barrel shaped ones I have found on this board.
Finally, I have included a picture of the machine itself. If it helps identify the machine, (the tag with identifying information is missing) the Astoria metal label on the back, upper left shows a red outline map of the world behind the name Astoria.
