The only other adjustment I made was to tweak up the pressurestat a bit,it's now at 1.4,which is probably high,but at the factory setting(1.2) I wasn't getting enough steam pressure to do a decent job.
...I disassembled the grouphead and applied some vaseline to the O-ring(part#16)...
GerryW wrote:... how do I reply to individual responses in a thread? ...
Dow Corning 111 Valve Lubricant and Sealant can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft vacuum systems, electronic and ignition systems, among others. It can be used as a sealant in applications such as vacuum and pressure systems, equipment subject to washing and harsh environments, electrical service entrances and underground connections, and transformer gaskets and equipment enclosures.
Dow Corning 111 Valve Lubricant and Sealant maintains a serviceable consistency from approximately -70° to 400°F (-57° to 204°C) and has NSF 51, NSF 61 approval and is acceptable as a release agent under FDA 21 CFR 175.300, when used in accordance with that regulation.
Petrol-Gel Sanitary Lubricant
by McGlaughlin Oil Co.
* Tasteless and odorless
* Will not taint
* USDA Rated H-1
* FDA approved
* Impervious to water
* Operating Temp 0° - 185°F
* High melting point of 195°F
* Technical white grease
* Valves, pistons, pumps
* O-rings, guides, slide mechanisms, and more
GerryW wrote: The only other adjustment I made was to tweak up the pressurestat a bit,it's now at 1.4,which is probably high,but at the factory setting(1.2) I wasn't getting enough steam pressure to do a decent job.
cannonfodder wrote:The temp is controlled with a pressurestat, just like the controls for a HX machine. Since pressure is directly related to temp, the boiler pressure will give you a very close guess as to the boiler temp. You get some cooling as the water passes from the boiler to the grouphead.
Boiler pressure (bar) Water temp (Fahrenheit)
1.0 253
1.1 255
1.2 257
1.3 259
From Dan's HX Love Article
Problem with the Pavoni (and my Gaggia) is that the GH is directly attached to the boiler. The longer the machine is on, the hotter the GH will get. Eventually it will overheat and have to rest for an hour to cool down.
The 1.2 boiler pressure sounds high for these types of machines. My Gaggia runs about .9 much over 1 bar and you hit the red on the pressure gauge. There is also a pressure relief valve in the boiler cap. If you turn the pressure up you may blow the valve (think of opening the pressure relief valve on a pressure cooker, WOOSH).
sophiesbar wrote:Do you mean a lack of steam to froth the milk?
