Linz wrote:But here's the point: When the water comes out into the group it will drop to normal atmospheric pressure, and therefore the temperature must also drop to 100C (212F). The excess temperature will be used to convert a small amount of the water to steam. Changing the temperature of the boiler water will have little or no effect on the brew temperature.
I reckon Espresso physics are about as well understood as women, and I'm not sure which is more temperamental, my lady or my Pavoni.
Hi Linz,
Super observation. Never looked at it like that. Water cannot possible go through the puck higher than 100c unless the puck is airtight which I imagine it is not. But as Timo mentions, the higher the pressure in the tank the sooner the grouphead is overheated and the less the water will be cooled to a good brew temp when extracting. A simple solution to this overheating problem is to rub a cold towel on the grouphead if it seems too hot. I only have to do this when I am making espresso for a few friends consecutively. Experience will tell you when this is needed.
As far as the water temperature is concerned on a lever, it is a difficult thing to control. But it is easy to stay within a good range and with experience this range becomes smaller.
At home, I just switched from my Europiccola back to the Brass beauty (La pavoni Ambassador excellently modded by an alchemist, our Alchemist, for brew pressure reading). I had switched to my Europiccola for a while because I enjoyed that it had no gauges and needed a break from constantly adjusting my arm to a 9 bar pull, quite a feat, thought I might get bursitis. Well now that I have switched back to the gauged-out brass beauty, on the first pull, I see that I am automatically close to 9 bar. Must have built up my strength. The espresso is fullbodied (2/3 panama 1/3 Sumatra roasted on my caffe Rosto a woody black just before the oils).
Back to the temp observation, With a bit of experience, it becomes less an issue and compensating for it will become second nature. Fortunately even when the temp is off the espresso is significantly better than most. Especially with freshly roasted, properly ground beans. Absolutely as important as the temp of the water.
As far as women or people are concerned I can never compare them to any object or to each other, nor in any way exert some kind of control. Just let people do their thing and when the gods are aligned miracles will occur. Physics applies only to the physical, A minute amount of what is really happening in our world.
