My first plunge into home lever ownership was the purchase of this Grey Caravel which I got on Ebay italy while I was in Florence. The surprise was it came in great condition, with a double and single basket, working, shiny and well packed. It didn't leak until I got started with it and had pulled a few single shots with my wall-mounted PeDe grinder. (the grind was still too coarse and the coffee was-not surprisingly--terrible). But then it started to drip. And drip. So I pulled it apart, wow, is this cool or what! It comes apart like a chinese puzzle without any tools! But cleaning and lubricating didn't help so I did go out and buy the ring clip pliers to pull apart the piston so I could change the O ring. (They seals weren't bad) but I replaced the O ring and the piston seals once I was there and lubed it up with Dow 111. No more leaks.
Now the grinder issues. I have this wall mounted PeDe grinder that dialed all the way down made a rather fine but not powdery grind and was non uniform; some of the grind was powder some was grittier. But despite weighing the beans with a gram scale and trying 7-8g in the single basket I could never get any crema, the coffee was very thin and very bitter (I'm using locally roasted arabica beans 3-4d old). The Italians would call what I got "una brodaglia" (nasty thin broth). I tried packing tighter/more/less/etc but never got anything with anything but a hint of instantly vanishing crema (although waiting for the water to cool a bit before pulling a shot got rid of most of the bitterness and left me with Moka pot flavors).
So, I pulled out plan "B". The commercial, cast iron, volkswagon-beetle sized grinder I bought years ago hoping I could use it to grind wheat for flour.
No luck. It's just too big....the hopper isn't designed to feed beans to the active part by the gram but by the kilo and although I didn't bother to open it up I could never get anything finer that coarse French Press grind.
So back on the table for decorative purposes it went.
Plan "C". I went back to OKE torreffazione (O.K. coffee roasters) just down the street.
They are one of about a half dozen still-active coffee roasters in Florence (although they are tiny they work with La Marzocco to provide beans for their shows/fairs). They steered me to their all-arabica blend (all central and south american coffees)which they let me sample from a pull on their La Marzocco machine they have in the back for testing purposes. They also sold me some of their other "hi quality blend" that includes a small amount of robusta beans (10%) which is more popular with the locals.
They were happy to grind a small amount of each to take home (I bought 100g of each) ground as for their espresso machine. So I raced home to check out a grind I knew wasn't too coarse.
Well, too fine. I choked the machine on the first try filling up the basket and lightly tamping so I went back to my gram scale and 7-8g now barely reached up 2/3 of the single basket (with the PeDe 7g barely fit in the basket.) Still choked the machine.
All that was left to do was mix a bit of this finely ground coffee with the freshly ground stuff I could pull from the PeDe. It wasn't much better than the moka coffee I can get from the stove top.
Plan "D". I'm heading home to california and ordered a hand grinder (from OE). I'm pretty sure it's a grind issue and once I can actually adjust it I'll post back with my results.
