SiD- wrote:That's right, double pullls should be avoided, because it sucks coffee grounds back into the boiler and you don't want to pull the machine apart to clean the boiler, right?
SiD- wrote:Same thing goes for updosing (overfilling) the filter basket, be careful with that.
I suggest to use the LM single basket and fill + tamp only into the 41mm middle section.
SiD- wrote:If you take the machine apart for cleaning, it is a good idea then to adjust the thermostat to your taste.
JonR10 wrote:First - I'm not sure if the piston seal arrangement could allow any coffee back into the boiler (I never had this problem even with 2 full pulls on one shot). Second, the boiler is OPEN on this machine...meaning you could just rinse it out and turn it upside down to drain if coffee ever did get in there.
timo888 wrote:http://www.home-barista.com/forums/userpix/915_mini_gaggia_inside_dirty_boiler_1.jpg
Peppina Marries MiniGaggia
