Oops, indeed I'll have trouble to install the spring back!
You have to compress around 16 to 20mm to reach the rod thread, probably 30 kgf...
Well, spring removed and measured. It's 120mm long, 47.7mm external diameter, 5.05mm wire diameter, 6 coils. Seems to be stainless steel. Should I consider 6 or 5.5 coils? On the spring designer calculator I'm using, if I put 5.5 coils it gives almost the exact weight of the spring, and a little bit more force to compress it.
The spring installed has 78mm (42mm displacement) and with the lever fully pulled it has 44mm (76mm displacement). So the pressure of the Mini Gaggia seems to be from 5.5-6 bar to 3-3.4 bar (considering 6 or 5.5 coils). No high accuracy here, but it makes sense for those who use the machine, right?
Maybe a 5.5mm wire, keeping the external diameter, could fit (36mm is the minimal diameter to the spring fit the top of the boiler) and it should give from 8.8 to 4.8 bar. But I think a additional spring could improve the maximum pressure without adding pressure to the pin when the lever is up. There is a spring shop that has a 25mm diameter, 3.5mm wire, with 78.3mm size and 9 coils, that could give around 3 bar when compressed 34mm. I could test this one.
Considering one should put 60 kgf more, and the lever to pin ratio seems to be almost 1:9, that would require 7 kg more over the original 12 kg (seems to be ligher when I pull it).
Márcio.
