piwonka wrote:as far as temping the group. how accurate are those electronic temp readers that you can just point at stuff and it reads the temps.
I have done a bit of experimenting with this recently.
Most infrared thermometers only work on non reflective surfaces, so getting a measurement straight off the chrome is not an option. I place a strip of blue painter's masking tape on my grouphead and take measurements off of that. I have always removed the tape right after finishing my session, and it comes off cleanly with no residue left behind.
I have two infrared thermometers, both inexpensive models: a Thermoworks TN-1 with 1:1 optics for short range measurements, and another with 12:1 optics and a laser pointer, intended for longer ranges. The TN-1 works well, as I can easily hold it just fractions of an inch from the tape. My other thermometer with the laser does not work as well, as the laser is not aligned precisely enough to point to exactly the same spot that the reading is being taken from. I can eventually get the reading by moving the laser off the tape, but it's trial and error. So, YMMV depending on the thermometer model.
I have found it useful as a learning tool to measure the grouphead temperature before my shot and then correlate the temperature reading to the shot taste. I have no idea what the absolute accuracy of the thermometer is, or how the surface reading relates to the water temperature -- I am only assuming there is some correlation between the reading and the actual water temperature, and that shots taken at a given reading on different occasions are at least more likely to have similar temperature properties than two shots taken with different grouphead temperatures. My tasting results seem to bear out this correlation -- at least at a gross level -- but other than that I have no independent method of determining the relationship between the grouphead surface temp and the actual shot temp.
One useful technique I discovered during my experimentation was that I can raise the grouphead temp without flushing any water, simply by raising the lever up half way and then pushing it down again. I have found I get more predictable results (i.e. I can raise the grouphead temp to a target range with some consistency) by using N lever half pumps, than I was able to by doing a water flush for N seconds (I found it very easy to overshoot when using the water flush approach). I'm currently using 4 half pumps, which gives me a grouphead surface reading of 195-200 before the shot.
