Gaggia Factory / Millenium Piston & Sleeve
Postby Bailey on Mon Jan 10, 2011 12:15 am
Hello,
My Gaggia Factory (106) machine has had some trouble with the plastic sleeve and piston, after reading a few threads here by owners of the Gaggia and La Pavoni Millennium with similar problems I intend to replace my plastic piston with the brass one. I've also seen a mention that after this replacement the plastic sleeve becomes unnecessary. Is this correct? If someone could shed a bit of light on this I'd greatly appreciate it. Mine is a tad bit cracked and if need be I will replace it but if it is no longer needed after installation of a new piston, even better!
Thank you,
B.
Bailey
Postby orphanespresso on Mon Jan 10, 2011 1:23 am
Both the plastic and brass piston are the same size...you still need the sleeve.
orphanespresso
Postby Bailey on Mon Jan 10, 2011 2:19 am
thank you for clarifying, it didn't entirely make sense that you wouldn't need it w/ replacement but i was a tad bit confused by the above mention.
Bailey
