Gaggia Factory doesn't pour boiling water
Hi guys!
I really need help cause there is no service company (lever machine) in my city.
So problem is Factory G106 doesn't pour boiling water. After machine is turned on, pressure grow steadily - no issue with this.
I don't reveal any steam leaks.
Piston pulls up and down as usual.
To prove my words I attach video. Please help!
- rotchitos
the dip tube must be clogged.
Limestone?
Limestone?
http://machines.cafeslevier.free.fr/
I look for persons to translate into English one or + pages of my site... :-)
Addition.
Steam from steam wand is warm but not hot as used to be. And metal plate (bottom of machine) is not so hot as used to be.
Thank you for answer! So may be. Need I unscrew 2 bolts to unmount dip tube?rotchitos wrote:the dip tube must be clogged.
Limestone?
- rotchitos
exactly
Thank you!
I have to make a video manual!
- homeburrero
Another very likely possibility in this machine is that your piston has come unscrewed on the shaft. This happens all the time on Gaggia/Pavoni with the plastic piston, and causes that symptom exactly.
Pat
- rotchitos
effectively. removing the group will give us the answer.
Ok, guys!
I unmounted dip tube and extracted piston. Found some stuff like a unguent in dip tube.
Rinsed all this stuff. Finally everything is ok.
All procedures took 30 minutes.
Thanks for your advices!!!
