I am trying to disassemble and restore the Gaggia by myself. But,one of screw breaks at the boiler.
My friend suggests me to remove the break-screw by using 'Wire Electrical Discharging'.
Anyone has other suggestions (easy way) ?
Joe
Paul_Pratt wrote:p.s. I forgot to add there is no way I would risk the electric erosion method.
Paul_Pratt wrote:You have to treat these babies with care. I would first soak it with some penetrating oil for a week or so. Then you start the process of drilling it out. You may get lucky and can use a screw extractor bit but most probably it will need to be drilled out and re-tapped.
drgary wrote:Hey Joe,
I had lots of practice dealing with stuck bolts with my Conti Prestina rebuild, which is still in progress.
Paul_Pratt wrote:I did a bit of work on my own Gaggia this week, an Orione. It's a total wreck.
9 of the 10 bolts sheered off and this was after penetrating oil, heat and an air impact wrench. Oh well drilling out 9 holes is better than 10 I suppose.
When I get around to this boiler end plate I'll take some photos of the process I use and hope it will be successful.
