I have been lurking this forum for many months and this is my first post. Thank you all for sharing such great expertise and information. I was wondering if any of you excperts can help me with the shot quality of my Gaggia Achille.
This is not my first machine. I have had good machines in the past and I also drink very good coffee on a regular basis both at home and when going out. I love creamy buttery aroma-rich shots and some of my most used beans are Intelligentsia, Gorilla, 9th St, Espresso, La Colombe and Gimme. From the more commercial brands, I usually prefer the Italians; Kimbo, 1882, Dansei and Bristot.
I am new to lever machines however. I've had my Gaggia for about 3 weeks now and I am going through coffee at the rate of gasoline usage by a Persian gulf oil monarchy. Making my morning Americano usually I go through about 2 full tanks of water and 4-5 doses until I give up and end up with something that tastes like Folgers. I just can't seem to produce a decent shot. Regardless of 7g dosage that is pressed to the limiting rim with 60-70 Lbs tamping (!!!) at a very fine grind -I get pucks stuck to the showerhead while my portafilter and basket come out clean. That had tripled my paper towel budget in the past few weeks and I spend most of the morning cleaning the machine up.
Typically, the single shot basket yields very poor crema in under extracted sour shots. (I press it just right to have a drizzle, not too fast. I know what the drizzle speed is supposed to look like).
Out of frustration I switch to the other basket which is triple in size. I fill it half way and I get what looks like decent crema on top but has no depth to it. The shot is flavorless/bodyless and having so much espresso, I need to toss one espresso and only use the other to make an Americano at the right strength - a huge waste of very expensive coffee.
So here's what I have:
- I am vigilant about pressure to speed of drizzle ratio
- I know how to tamp very properly
- My beans are fresh and high quality
- Due to real estate limitation (I live in Manhattan, NYC apartments are small and expensive) I cannot afford the space for a proper grinder. I do however have a good network of coffee roasters and baristas around who happily grind the coffee for me at whatever setting I desire using some very good grinders. All of the grinds from brands I mentioned above have been tested anywhere from 0.2 to 2.0 on a perfectly calibrated newer model 18-step Mazzer commercial grinder.
The only thing I can think is that I still haven't found the right grind. One of the best baristas I know (owner of 6 amazing coffee shops and roasting house) had told me that I should go coarser and not finer with the ground. It indeed produced far better results with more crema, but having it so coarse, I just can't seem to keep a puck together, even at very heavy tamping.
I know that I am doing something wrong and this machine can do the magic. Can anyone please advise?
