I am a total noob to high quality coffee (well, I've always drank from a moka pot, so I guess I could have done worse!
Anyhow, a couple of questions, and please keep my lack of experience in mind if something I mention does not make sense...
1- In the Achille "guide" here on HB, Cannonfodder mentions that he gets 2 oz of water per complete lever pull sans PF... I get just a hair under 1.5 oz, both with PF completely removed and with coffee-less PF in place.
a) Does this indicate a problem? Mine is a June 2006 model, maybe they changed the displacement? Doubtful I know, but what else would explain such a big difference?
b) Does this mean that for a double I should just use two full pulls. Taking into account the "overhead" that the puck absorbs leaves me at 2.5-2.8 oz for a double.
2- I too had plenty of squeaking and the bubbles going back into the water reservoir, and when I ground too fine had the major leak down at the base level that wet all of the electrics down below... this was due to my mistake though, I was putting waaay too much force on the lever when that happened, something told me I should have quit, but I didn't listen. So I proceeded to disassemble and lube everything (couldn't find Dow 111, so used 90% Silicon Grease from Ace Hardware labelled as "non-toxic", safe for O-rings, upto 450 degrees F ,and for faucets and such, so I figured: close enough.) This really quieted the machine down, not a single squeak anymore and no more bubbles in the reservoir once primed.
a) The shots I pull have tons of crema (about 15-20% of the shot glass) that lingers for plenty of minutes. I haven't timed it with a watch, but counting Mississippis tells me I'm between 20 and 30 seconds, but have no clue how many pounds of force I'm applying, although it "feels" right (don't laugh, I know I'm new). Yet, I in the cup, I taste a bit of bitterness, maybe it's supposed to be this way, and I don't know any better, but I just want to make sure I'm not over-extracting or something. When I add sugar all is well, but that's not what I want out of my espressos. Compared to espresso shots I've had at Starbucks, mine taste a good bit better, but this doesn't say much according to what I read here. I was just expecting such a lack of bitterness that sugar would not be desired at all. If I've always drank moka coffee with sugar, should I expect to like a well pulled espresso with no sugar at first taste, or does this need to be acquired? My plan is to go to a true-blue cafe and taste what my goal should be.
b) Even after the o-ring fix, my pucks are soaking wet. What is required to get them to come out dry and in one piece?
Oh, btw, I'm using fresh beans bought a few days ago from Caracolillo here in tampa, ccmcoffee I think is their web name. I bought their Espresso Roast. It's pretty dark, oily sheen to it. Grinding in the Kyocera minutes before use.
Anyhow, I'll leave things here for the moment... there's more, but don't want to overwhelm.
Most importantly, despite all of the above, I'm really enjoying this machine, and even using the wand attachment (and thermometer) am frothing milk better than any locally purchased place nearby... my wife LOVES the cappas, so all is well. I just want to get better-n-better.
Thanks!
Jesse
