ancap-usa.com: quality Italian porcelain coffee serviceware in the USA
Frothing with pre-mil La Pavoni
Postby paulvin on Fri Jul 15, 2011 9:02 pm
With the three hole steam wand on the La Pavoni you're meant to position the steam wand in the middle of the jug - vertical. This seems to be a physical impossibilty with my machine as the steam wand doesnt protrude far enough away from the machine to get anywhere near the middle of the jug. The best I can do is turn the steam wand behind the machine but then the angle starts to get excessive and I lose the vertical component.
So I'm stuck between scolded milk and extingusher foam at the moment. Any ideas other than sticking a tooth pick in a hole?
Or am I missing something?
paulvin
Postby RayJohns on Sat Jul 16, 2011 3:52 am
Check ebay or Orphan Espresso for a single hole steam wand tip. That will solve your problems. Also, the toroid steaming pitcher, from espro, is handy to have around.
http://www.espro.ca/toroid
Ray
RayJohns
www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Postby paulvin on Mon Jul 18, 2011 2:56 am
Thanks Ray,
$10 including postage beats $55 for a new jug.
paulvin
