From Scratch DB Home Lever
Hello all,
For the last few months I have been working on my take on the "Open Source Lever Project." Inspired by the Australium. It's been a wild ride, I've gotten lots of guidance from other HB members and have gotten to meet some really cool people along the way!
Now my project is to the point where I can begin testing, so I would like to share my progress thus far!
Just some quick info on the build:
-PID Controlled Heated La San Marco Group Head
-316L Stainless Double Boilers, each with 2.4L capacity
-PID Controlled Stainless Heating Elements (1650W)
-316 Stainless Fittings
-Joystick Taps
-Home Lever Dimensions
First, I received my LSM Group from another HB Member very shiny and sexy!
Then I started designing and constructing the boilers:
Just some rough CAD Drawings (That have since been through some minor revisions):
Boiler End Plates:
Boiler Pipe:
With some help I got them welded and pressure tested:
Then picked the elements and some cheap PID Controllers for testing(Arduino will be the final controller):
Worked on the Group Heater Design(And had the part 3D Printed):
Finally I was able to do some steam tests (Sorry for Vertical Video Late Night Working): Then I was able to construct a simple Frame for testing Components (Just for testing not the Final Design!):
Now I'm waiting on fittings to arrive then I can begin adding all the components(Safety Valves, Solenoids, etc).
Then finally do some real testing and tweaking before the final chassis build!
I'd love to hear your thoughts!
So excited for the first shot!
-Joystick Taps
Boiler End Plates:
Boiler Pipe:
- aecletec
I love these kind of projects!
May I ask the purpose of the 3d printed part and will it be the final product? My gut tells me that maybe the material wouldn't conduct well and might not be food safe?
Wishing you success!
I do have a question: why did you choose to NOT go with a reduced sized brew boiler? Forgive my engineering ignorance if this is incorrect, but wouldn't it use less energy to heat up/maintain temperature, thus less amps? Still, being a DB, I'm assuming you might be planning it as a 20 amp machine?
I wish I had 10 ml of the engineering/mechanical abilities most folks here have.
Thanks!
Well it came down to cost. It was cheaper to make two of the same size.
With both elements it puts me at a calculated ~14amp so I am aiming for a 120v 15amp machine
Edit: Also the full ~14amp will only be used during heat up. The energy required to maintain the correct temp with the PID should be less.
You're correct! PLA would not be a great choice.aecletec wrote:I love these kind of projects!
I actually 3D printed to test the dimensions of the part. (Fits nicely!)
In the end I'll have it machined or try to home cast it from Aluminum.
- aecletec
Nice! I wish you well and will follow with interestJorian wrote: I actually 3D printed to test the dimensions of the part. (Fits nicely!)
Wow this looks great!
I have a question, how are you going to get the brew water from the boiler up to/in the group? Is there going to be a pump in the machine?
Thanks!
I was thinking of using a controlled pressure transfer... But if that causes problems, Ill use a pump.
- Sponsor
Line pressure should be plenty of adjust-ability.Beaniac wrote:Wow this looks great!
Looks great Jorian, I really like that La San Marco group, nice that it has the space to directly heat.
Yes, super convenient! I have a few bids out for the aluminum heating block at the moment.
